Question about Amana Refrigerators
Hello, I have an AMANA side by side fridge with electronic display between the doors since 10 years.It seems to have a bad contact in the electrical cable going from the right door (fridge) to the main body.When I do open this door the display turn out and when I do close the door again or the bars are blinking and I have to push on the star on top of the display to restart, or nothing happen and the compressor don't run anymore. I have to open the door again and to play with the cable at the dowstair right of the door to get the display again. What can I do to solv
Posted by schellens paul on
  • 2 more comments
  • schellens paul Sep 11, 2012
    Many thanks for your help, John.
    I didn't notice I had receive an answer to my question because my PC had located the message in the "unwanted" file !
    Please accept my apologies.
    The serial number is : 0104123062
    The manufacturing nr is : P1320305WW
    In the mean time I'v called the technical service in Belgium where I was told that the only solution was to replace the fridge door !
    I investigated a little bit further and I located the problem coming from the multi-wired cable going from the bottom of the fridge door to the plug soquet at the bottom of the unit.
    It must be : - or a wounded wire coming in contact with the body
    - or a broken wire in the insulation, giving sometimes a bad contact.
    So, I dismount the inox plinth and his support plate to give more motion room to the cable, and up to now, it seems to work ! ...
    How can I locate the wire giving the trouble, if the problem occurs again ??
  • John Tripp
    John Tripp Sep 11, 2012
    I believe in this case there is possibly a pin plug connector down in the location you mentioned and moisture from water possibly has leaked and caused the plug wires to corrode. Try pressing the dispenser controls as you with gloves grip the wire bundle and move around to cause you to get some type of response. I won't have much luck with a wiring diagram on models outside the USA, sorry. If it has not been removed there should be a Technical Sheet in a pouch behind the kick plate where you are going to be checking the wiring. I will try to help if I can, Thanks, JT
  • schellens paul Sep 14, 2012
    Hi John,
    I 've checked the plug and there is no corrosion !
    I'm sure the origin of my problem is located in the 20 cm of wires going from that plug to the bottom corner of the fridge door !
    There is insulation tape around the wires and probably, as I already mentionned, one of them is giving a false contact.
    But as I said, now that those 25 cm are totally free and without any contact whit the body, It seems to work properly.
    If the trouble succeed again, I'll come back to you !
    Thanks again.
    paul
  • John Tripp
    John Tripp Sep 14, 2012
    I was hoping to find the break at the pin plug. I will be here if you need answers. Removal of the dispenser facade and pulling new wires will be next...Thanks, JT
John Tripp
  • Amana Master
  • 4,656 Answers
Here is a wiring diagram of a typical Amana Side by Side Refrigerator. In the top left corner you will see the box saying Harness FZ Door and Door Hinge Click HERE to view. I'm not sure just what model number you have but this diagram will help in giving you an idea of what plug and sections of wiring you and I can assist you in locating your bad connections. Look under the top hinge plastic cover and see if connecting or try pushing the plug assembly together more firmly. If this helps please let me know and please look around your fresh food section door and send me your model number so I can point you to the correct refrigerator wiring diagrams and tech support. Thank You, Sea Breeze
Larger View
Hello, I have an AMANA side by side fridge with el - 8_30_2012_4_37_09_am.png
Posted on Aug 30, 2012
  • 6 more comments
  • schellens paul Apr 14, 2013
    Hello John,
    I'm very sorry, but I've been out for a while... (sick)
    My fridge problem is till there, but I've located exactly where it is ! I've tried to join a picture, but I didn't succed.... I've already mentionned the multi-wired cable going from the multi-plug at the bottom of the body to the door through an hole in the right hinge.It is in that little pipe that one or more wires are broken under the insulation. It is a twisting point !
    I'm afraid I'm doing something wrong, each time I hit the return key to go to the next line, the message is send !!!
    My questions are : 1 How do I dismantle that door to acceed the broken point ?? 2 Does'it exist a spare part to replace the cable ?? many thanks
  • John Tripp
    John Tripp Apr 15, 2013
    You cannot dismantle the door without damage to the door. To replace the door would cost as much as replacing the refrigerator. You may be able to pull another cable through the door if you can find one in Belgium that is a replacement part if found there. Your best bet is to match the existing cable and splice the broken area if you know how. I am sorry I just have no simple solution....John Tripp
  • schellens paul Apr 15, 2013
    You are right ! Amana doen't exist anymore in Belgium...On internet I found the name of a fridge dealer supposed to repair existings Amana fridges. I called them, but unfortunatelly they told me that whith models having a V in the model number, it is impossible to replace the cable, my number is : SBDE 522 VW !!!
  • John Tripp
    Thank you for responding this way because I really did not have a simple solution for the repair of the control wires on your refrigerator. People come here for solutions and this time there was not a simple fix. On some models there is a conduit area that allows movement and space for the cable that goes through the top or bottom of the door and then goes to the dispenser control panel. That conduit will allow movement and pulling a new cable will be possible in those cases but many refrigerators have the foam filled after the cable is in place and once done this way there is no way to replace the cable and the door can be damaged if you try to disassemble. Hopefully you can splice the broken area by soldering and insulating the repaired cable where it exits and is most likely being twisted during movement. Again Thanks John Tripp
2 Related Answers
montgumree
  • 52 Answers
SOURCE: Side by side Amana freezer/fridge. When you close
Possibly need the hinges adjusted.
Posted on Jul 15, 2009
Anonymous
  • 153 Answers
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
Posted on Jul 21, 2009
My stove is flashing this code "-F1-" on the display, some of the buttons work and some do not. All of the problems started at the same time. Also, the front right side by the knobs seem...
Hello & Welcome to FixYa
Error code F1 indicates electronic control failure and is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Amana ACS7270AS Electric Kitchen Range
Amana electric range f-1 error code and beeping. model ARDS800WW
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Feb 02, 2011 | Amana ACS7270AS Electric Kitchen Range
Hello...we have a JCD2289AT that is 6 years old approx...frezer and ice maker are working fine butr refrig seems to not hear a cold temerature even after setting to the coldest setting. I pulled the unit...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 19, 2010 | Jenn-Air JSD2789GES Side by Side...
The door seems to be warped or tweaked in some way
Your fridge is not level. If you level it you will find that the door was fine , it was the fridge that was tweaked because it was not level and sitting correctly. Use a level, shims, and/or the adjustment screws on the bottom.
Jul 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana SBDE520N
its quite possible, that "the box with thermostat and small door fix on chanel for regulating cold air from freezer in fridge side", is not the problem, there can be a few diff problems, the fan in the freezer may n ot be blowing the air over, you may have a bad defrost thermostat, preventing proper defrost cycles and building up with ice preventing proper air flow. i would look into a little more before condemning the part your lookin at( damper control)
Oct 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
627 people viewed this question
Top Amana Refrigerators Experts
Marvin
Marvin
john h
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
