The pictures on the screen don't have the real colours anymore. For example: a face has mixed colours: green, blue, black etc and the colours keep changing all the time. As a result you hardly see it is a face.
Just buy an other remote control The internal printed circuit board of the remote control is cracked.
I don't think that is the problem. The problem remains when I manual set the TV on.
Make a factory reset tho this set. Download the user manual and refer it for details. To download it, check this link: http://www.retrevo.com/support/Philips-3...
SOURCE: Model: Philips DVDR3590H Screen:
Hi.
Issue of this kind can result from bugs in the software/firmware and can be resolved by upgrading your
recorder with the latest software (V1.61). You can find the download
and the included installation instructions in this page.
If you interrupt upgrade procedure or if you do not follow the instructions included in the download,the unit may result damaged. If unit is under warranty, call Philips first.
Below old upgrade instructions. Please read the updated instructions that are included with your download.
Upgrade Procedure Step 1 Step 2 Step 3 DVDR3570H/DVDR3590H
SOURCE: Screen changes color from white
push the vol up and then the vol down on the side of the tv or ch up then ch down, the set is stuck in a factory mode, this will clear it.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
