The remote is a 'One For All' URC-1629 the TV a Soniq e19z10a I need the proper remote code because in its manual the Soniq ones didn't do a thing (1298 1702)
SOURCE: NEED TV CODES FOR PHILIPS
Here are the codes for your philips tv:
SOURCE: need tv code list for urc-4605
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4605
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
SOURCE: Need Code for Proscan TV for my URC-3021 All in one remote
http://www.ofausa.com/remote.php?type=URC3021
you do
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
SOURCE: I need the codes to program the ONE ALL URC-2060 universal remote
Don't know the codesbut you can scan for it by doing the following:
If your remote has a 'Scan' button, do the following:
1. Press the VCR button
2. point the remote at the VCR and press the 'Scan' button.
This will get the remote to go through all of the codes it knows for VCRs at about 3 second intervals. Once you see the VCR state change, hit any key on the remote and it will be programmed for the proper code.
SOURCE: i have skandia universal remote and need code for
I have a BASE DV-4304 DVD Player and i need the code for my Skandia Universal Remote. Please Help.
