Nokia Asha 303 Unlocked Phone - Red Logo
rex biado Posted on Aug 29, 2012
How to repair WLAN connection in nokia 303
What is erro #006
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 29, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2445
Points
8
Canon mf 4412 turn the main power turn on/off swiss bord what price
1helpful
How to i connect my nokia e5 to wifii
Hi there
Select Menu > Ctrl. panel > Connectivity > WLAN wiz..
The WLAN wizard helps you to connect to a wireless LAN (WLAN) and manage your WLAN connections.
If the search finds WLANs, to create an internet access point (IAP) for a connection and start the web browser using this IAP, select the connection and Start web browsing.
If you select a secured WLAN, you are asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
I also found the full manual in pdf format which you can download from here
http://nds1.webapps.microsoft.com/phones/files/guides/Nokia_E5-00_UG_en.pdf
Good luck
Nov 11, 2014 • Nokia E50
4helpful
3answers
2helpful
I cannot connect my nokia c7 to the internet through wifi
Hi, pls verify below steps,
1.Whether WLAN switched on and has a good WLAN coveage. 2.Security settings on WLAN options
- Check the security modes (Open/WEP/WEP2 - this depends on your WLAN connection) - Check Security settings (Public shared Key settings)
3.You have to be a authorized user in WLAN network if it requires authentication login. 4.Open the browser on you mobile and select General->Connection->Always Ask, then it will prompt for the connection type, Select WLAN.
Thanks, Ramaly
My nokia e72 shows a message select connection search for WLAN it is annoying I set all settings to never run and applied all solutions mentioned in discussion forrum site. what else can I do?
Go to phone menu, select phone settings, select connection then select WLAN, select NEVER to stop searching for any possible WLAN signal. thanks
4helpful
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
8helpful
2answers
How to connect nokia 5310 with wifi network
How to connect nokia 5310 xpress for wifi
2answers
I have a Nokia E72 with WLAN as a built-in feature. How do I use this feature?
Whenever I disconnect the E72 WLAN (already in connected WLAN mode), E72 will reconnect WLAN again automatically within 1 second.
MANUAL
http://europe.nokia.com/find-products/devices/nokia-e72/specifications
6helpful
2answers
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
