Electric Mobility Merits Electric Wheelchair Scooter Battery Charger Logo
Posted on Aug 29, 2012
My merit scooter 550 lbs is blinking 7 blinks whats that mean
My Merits scooter S2454 power light blinks 9 times, what does this mean?
Hi Alfonse-
I found this link regarding your Merits S2454 power scooter.
http://www.merits.com.tw/english/products/detail-01.php?pid=19
Click on "Supporting Doc". Click on "S2454/2354 Owners Manual".
On page 15, it states that 9 flashes means "Other internal error".
At the bottom of the homepage for Merits power scooters, there is a number to contact for further help.
Hope this helps.
Roro does not go what does it mean when it blinks 7 x's in sequence n than all over again but does not go. Is there a way to fix this
7 is throttle trip Remove battery pack .remove key .charge battery pack then refit ,have a cupper then try with key back in .if this fails you need dealer
Merits dl5.2i dynamic has all the lights blinking and wont move what does that mean
It depends on the number of blinks that it's giving you.
For example if it blinks 4 times and there is a longer pause and then it blinks 4 times again, it's a 4 blink code and that means a right motor fault.
every number of blinks will mean something different
2helpful
Power eye blinks when turned on,but scooter will not move. Back brake lever is bent, but has been operating until this a.m. Back brake not releasing properly.
Count the number of times the power light blinks between pauses ie 4 blinks pause 4 blinks etc and this is the fault code If you have the users manual it might tell you what the code means. As long as the power eye blinks the scooter will not move and without knowing the error code I can't give you the definite answer Good luck
The right wheel is locked down and the scooter will not move--it shows a yellow x on the remote operation that there is a reason it wont move-is gthere an emergency code to stop it or what
sender the yellow x indicates a malfunction in the scooter. Does the x blink. If it does count the number of flashes and this will give the error code. Your users manual should explain what each code means. If Medicare paid for your scooter then they will pay for most of the repair cost. Call Repiar Xpress @ 1-877-581-3733 to ask if they have a tech in your area to check it for you Hope this helps
2helpful
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 times...
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
ZJ Limited
ZJ Limited
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
