if your going aftermarket cd player ask stereo supplier to give you a pioneer?? to ford harness just plug in and be on your way no wire cutting or files to blowif your going aftermarket cd player ask stereo supplier to give you a pioneer?? to ford harness just plug in and be on your way no wire cutting or files to blow
You can't post conmments that contain an email address.
1 --- White --- Black --- Left front + 2 --- Gray --- Black --- Left front - 3 --- White --- Purple --- Left rear + 4 --- Gray --- White --- Left rear - 5 --- White --- Red --- Right front + 6 --- Gray --- Red --- Right front - 7 --- White --- (none) --- Right rear + 8 --- Gray --- (none) --- Right rear -
Harness 2
1 --- (not used) 2 --- Black --- Green --- Radio Ground 3 --- (not used) 4 --- Orange (thin) --- Black --- Radio Illumination 5 --- Green --- Yellow --- Radio switch 6 --- Black --- Yellow --- Radio Ground 7 --- Orange (thick) --- Black --- Radio 12V
Instead of plugging the factory harness into the radio an adapter might be needed.
ref. link: http://www.carstereohelp.com
the above diagram is supposed to match your radio from the factory. The documentation with the new radio should provide the pins and plugs and what is on them. The correct plug or adapter should match up with the factory harness and work correctly.
A 4.0-liter V6 engine with a 4-speed automatic transmission is standard on all 12 models of the 1996 Ford Explorer. -------------------------------------------------------------------------- Car Key Programmer
most stero shops, best buy and some walmarts will have a 15 to 30 dollar plug that plugs into the factory harness and wires color for color to the aftermarket radio. good luck
hot at all times: blue/red hot in acc or run: blue/black ground: black illumination: red/black + green RF speaker: blue/white + orange RR speaker: black/white + blue LR speaker: black/red + red/blue LF speaker: violet + pink this is for factory am/fm stereo non premium sound
There is no user repair procedure for this problem, the factory repair manual says REMOVE PLAYER FOR REPAIR BY AN AUTHORIZED FORD ELECTRONIC SYSTEMS REPAIR CENTER.
FixYa.com claims they have factory repair manuals, they have nothing of the sort, this is not to say some experts may have manuals, we do, but we work from home and in most cases have a small library. Experts are not employed by FixYa.com, we help free of charge as much as we can with the general automotive knowledge we have learned while working as auto technicians, specific test values, repair procedures and illustrations are unique to each car line, these are not in most cases available to us. Thanks for using FixYa!
HERE YOU GO ALL WIRES U NEED PLEASE RATE ME GOOD LUCK WILL WORK GOOD!!!!!!!!
2003 Ford Focus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange/Black (Thick Wire) Radio Switched 12V+ Wire: Yellow/Green Radio Ground Wire: Black/Yellow and Black/Green Radio Illumination Wire: Orange/Black (Thin Wire) Radio Dimmer Wire: N/A Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: None Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Wire (+): White/Black Left Front Speaker Wire (-): Gray/Black Right Front Speaker Wire (+): White/Red Right Front Speaker Wire (-): Gray/Red Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Wire (+): White/Purple Left Rear Speaker Wire (-): Gray/White Right Rear Speaker Wire (+): White Right Rear Speaker Wire (-): Gray
