My turntable wont turn on. i just hear a popping noise by the on switch
SOURCE: vestax pdx-2000mkiipro keeps blowing internal fuses
You have a short in your unit, and you will need professional assistance in determining the cause. You might also want to try a different outlet. If it fails, then you'll need to bring it to a service center for repair.
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
SOURCE: i carnt remove the turntable platter can anyone help
The platter needs a drop of oil as the platter and motor shaft is a machined fit, Via brass upside down v as the platter will be reversed ie: a A WITH NO LINE . You can place two plastic wedge shaped blocks ,one on each side of the platter with even pressure and work up.
SOURCE: hi, have been given a vestax pdx 2300 turntable
Is there a speed control switch? UNPLUG and try spraying contact cleaner into the speed control. IF that doesn't solve it, then back to the manufacturer.
SOURCE: my turntable keeps skiping for no reason, no
What is the weight on the stylus? Flip the protective shield
down to protect the stylus if available. Tare the tone arm (adjust the counterweight
on the back of the arm until the arm floats perfectly level), then hold the
counterweight and turn the dial markings to read zero. If you cannot find the recommended
mass for the stylus you can use the average weight of 3g. Verify your tone arm
is still floating in the center and the arm is perfectly level. Turn the
counterweight until the dial indicates the specified weight of the cartridge
manufacture specification sheet or you can set it for 3g if you do not have the
specification
sheet.
SOURCE: Does the platter of the vestax PDX-2300 mk 2 fits
Hi ezradf ,
i am afraid no it will not fit, the PDX-2300 mk 1 has a bigger fitting then the Mk 2.
