Dell Latitude E6400 Laptop Computer   PC Desktop Logo
Question about Dell Latitude E6400 Laptop Computer PC Desktop
Latitude E6400 PCI Simple Communications Controller missing
5 Related Answers
Anonymous
  • 75 Answers
SOURCE: no pci simple communications controller driver
you will need to install the modem driver please check the model no and the modem that you have on the system, select appropriate os and download the appropriate driver from dell support site. Dell support
If you can figure out which modem is in your system and you haven't ever replaced it please call Dell tech support and provide your system service tag they will be able to help you with this aslo you can check your system configuration on the site itself if you have the service tag ready. check dell system configuration
enter the service tag and check under original system configuration will be listed as MDM
Posted on Feb 11, 2009
dealt_soul
James Bradburn
  • 299 Answers
SOURCE: cant find ethernet driver
Try the program Driver Max. You can download it for free and update needed drivers.
Posted on Mar 17, 2009
Anonymous
SOURCE: multi media audio controller pci
pci simple communications contoller
sm bus control
video controller vga compatable
I Have A Service Tag No. but when i Write the Number He Is Not Working
i Need Your Help
Posted on Dec 12, 2008
Anonymous
  • 79 Answers
SOURCE: pci simple communications controller not found
That would mean you need a modem driver installed for that PC, or your modem is bad. Now this is refering to a dialup modem not a broadband modem.Goto Dell website and under support you can enter your PC moodel number and download the Communication Modem Driver. I have provided you a direct link below:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=PLX_PNT_P4_CEL_170L
If this doesn't help, seek out a repair shop and get a new modem installed.
If this helps please rate my solution.
Posted on May 11, 2009
Anonymous
  • 17 Answers
SOURCE: need to find a pci simple communications controller driver
Just go to the controller's manufacturer's website and click on Support. You can download drivers from there, or even just Google it.
Posted on Dec 27, 2009
1helpful
Sony vaio vpcy21s1e/p
simple communications controller is likely a modem, sound card, or network card. If your sound was not working, you would know, and similarly with your network. So try sound card drivers next.
1helpful
6helpful
2answers
Driver HP G62 corei3 pci simple communications controller
if you have pci simple communication controller as unrecognized device it's mean that the modem driver are missing. just click this link to download the driver
My PCI Simple Communications Controller is missing from the drive
Go to start and select control panel. Select Device Manager, look for the missing or flagged up icon. Select it and choose Driver then Update Driver from the menus. Let Windows go online to find a driver and that should be that.
Hope that helps.
1helpful
Pci simple communications controller could not find a driver so there's no internet, board is an Asus p5smxse with 2 chipsets, one on the north and the other on the south. sis 968 and sis 671fx
Enter your bios and make sure you're lan is [Enabled].
Open the link provided below;
http://www.asus.com/product.aspx?P_ID=fLSzpcTDJYT0rgS6&content=download
Choose you're operating system from the drop down menu.
There is one LAN driver, Sis Driver V2.0.1039.1070 for Windows 2000/XP/2003/XP 64bit/2003 64bit. Create a folder on your desktop and name it LAN. Download the LAN driver into the LAN folder. Uncompress the zip file, keep the uncompressed file within the LAN folder. Open windows device manager. Find the pci simple communications controller. Right click on it once. From the pop-up menu left click, update driver. Follow windows instructions. Find the Lan folder on you're desktop and open it. Left click once on the newely created Lan folder so it is high lighted. Click OK. Windows will find the correct software and install it for you. When finished restart you're system. Check windows update for hardware and software updates after windows restarts.
More often than not (pci simple communications controller) points to an audio driver missing but LAN controllers are included.
Cheers!
Mike
1helpful
Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
2helpful
Need a ethernet controller & pci simple communications controller
Try this link: http://partner.atheros.com/Drivers.aspx
You might be able to find something here.
1helpful
Multi media audio controller pci simple communications contoller sm bus control video controller vga compatable all with yellow question mark against them
sm bus control
i Need Your Help
1helpful
2answers
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
Clive
Clive
Steve Sweetleaf
Steve Sweetleaf
