Radio screen still works as well as navi, & cd , but no sound?
When you have no sound on the radio the first thing to checkl is the speakers. Using the smallest voltage battery you can get hold of and handle easily (AA or AAA) conect +(ve) and -(ve) terminals of the battery to the 2 speaker connections. If the spreaker is OK it will produce a cacling sound. If non, replace.
If speakers are OK the trace connection from radio/amp to speakers. If OK then radio needs attention.
SOURCE: radio and cd player stoped working suddenly
the security on the radio has been tripped you need to take it to a GM dealer and have them run a code to unlock it CAL means calibrate
SOURCE: 2003, 330Ci radio, navi buttons on the dash not functioning.
hello . ok first try disconecting the nave unit on the trunk if the radio comes up and the buttons work you have a bad nave unit (very common ) . other option look for radio fuse in glove box top open white tabs on top diconect the fuse and reconnect to see if it will restart the radio pannel if not replace the radio pannel .
SOURCE: CLOCK DISPLAY & RADIO DISPLAY NOT WORKING,
I had this same exact problem. i found a blown fuse in the panel on the drivers side just inside the door well (On the end of the dash on the driver's side) . to save me I do not remember which one buy as I recall it w as a 15 amp fuse. That fixed the problem. you will need the code from the factory to reset the radio.
