Televison & Video Logo
Sandy Walen Posted on Aug 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does it need the T con Board replaced or the inverter board?
I have a polaroid TLX03210b Tv and the screen is black and no sound when the blue light is on. after it has been on for a few seconds the red light inside on the board starts to blink. if I shine a flash light on the screen when I first turm the set on I can see the Word Polaroid come up on the screen for just a second. but the screen is very dark.
Anonymous
Level 3:
Top Expert:
  • Polaroid Master 14,553 Answers
  • Posted on Aug 29, 2012
Anonymous
Polaroid Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2714933
Points
48227
The only way to know is guess and install a replacement board or boards if you can even find them--this is the nature of these types of sets and oh Yes, it does not have to be a board as a display panel is not impossible.
5 Related Answers
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on May 04, 2010
SOURCE: sound but no picture polaroid tlx03210b
Take a flash light and point it close to the screen . do you see a picture.
You have a bad back light or inverter the powers the back light. in any rate here the unit will need a repair shop because these are hard to get to you have to dig.
let me know ether way/
thanks for asking your questions please do rate and leave feedback.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Anonymous
  • 1779 Answers
  • Posted on Nov 30, 2009
SOURCE: Polaroid Mdl# TLXO4240B LED blinks red and blue,
Disconnect the jack lead that goes to the inverter board and see if you have 24v from the P/S. If you don't then you should replace the power supply. If you have 24v, then the inverter board is bad.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jul 30, 2010
SOURCE: Polaroid TLX-01511C screen goes dark after power on
If the screen is still glowing, then you may have either dead T-CON board or the main board. Dead backlight inverter board will not get any glow on the front or the back of the LCD panel.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Anonymous
  • 2178 Answers
  • Posted on Oct 24, 2010
SOURCE: I have a Polaroid 42" TLX-04244B. When turning the
The Inverter is trying to produce the high voltage to light the backlight. It looks like it cannot hold the charge to maintain the high voltage level in order for it to stay on - you get a momentary display at initial power-up thus see the logo. Replace the Inverter board.
Anonymous
  • 62 Answers
  • Posted on Nov 04, 2010
SOURCE: polaroid tlx03210b 32" tv has sound but picture
clean the LVDS cable
I have a Polaroid TV FLM-373B it was dead replaced the power board now I have picture and sound. But I still have a dark spot center lower screen. Is this a T-con board problem??
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
How to fix black screen on Polaroid 32" wall mount tv
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Replaced all caps on power supply board TV worked for about a month now Blue comes on and sound, but screen is black.
http://electronicshelponline.blogspot.com/.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
TV turns on, but the screen is very dark, almost completely black.
It sounds like your backlight is out or barely functioning. Try replacing the inverter board(s). Since you can see a picture, the T-Con board is probably okay.
Polaroid LCD tv - model TLX-04244b . Flashes the blue polaroid screen then goes black ,I hear a buzz coming from the inverter board. I have replaced both inverter boards and the same problems exisis .
I just changed out the invertor boards and mine was fixed. I had the same problem. Im not a TV repair man but replace the board thats buzzing and it will work again.
1helpful
Polaroid tlx03210b has sound no pictures
This is a common problem with this model you need a new main board. You can google around to find a part number, I would recommend getting the part number from the main board in the TV to guarantee compatibility. It will need replacement. If your a do it your self-er you can find more info and search parts here:
Polaroid TLX03210b Main Board Parts and Repair Info
Why does my polaroid tv screen black out?
  • Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
  • To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
2helpful
Tv comes on and then goes off in seconds like breaker is kicking
Yes,Ur tv still have sound after the video dies in a few sec.?Yes,there are sound than ur LCD inverter board is dead.No,there are no sound than ur T-con board is dead.U have a little machanical skills take ur tv aparts.The LCD inverter board is a long board in shape and it sit sides of the tv right or left.The T-con board sit at the botton center of the LCD screen.Tries websites like Shopjimmy.com,Ebay.com to buy refurbish boards either the LCD inverter board or the T-con board for the replacement.
4helpful
3answers
Sound but no picture polaroid tlx03210b
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
