Question about Sony KDS-50A2020 Television
Green tint on screen especially with dvds. picture also cuts out for a few minutes every hour or so on our sony kds-50a2020
Picture gradually looking green all over. picture cuts out for a few minutes here and there while the sound stays perfect. any ideas? TV is about 6 years old and we have changed the bulb once. Thanks
Posted by Ryan Mckinney on
SD Tech
    Top Expert:
  • Sony Master
  • 14,553 Answers
Usually in this set if screen gradually changes to something other than black and white the optical light engine is the problem---major part.
Google the model number with "problems" or "light engine" to learn more.
Posted on Aug 29, 2012
5 Related Answers
Anonymous
  • 135 Answers
SOURCE: the picture appears to have a green tint to it
The optical block is failing. Contact SONY for a replacement. They have extended the warranty or replace the sets
Posted on Jan 31, 2010
Testimonial: "I had no idea that Sony had extended the warranty, thanks a lott! "
Anonymous
SOURCE: Sony KDS-50A2000 screen is in green tint
My Sony KDS 50 A2000 is 17 months old. Its the 50 Inch SXRD projection model. About two weeks ago the screen developed a green tint with cannot be tuned out, then a few days later the message began to appear on the screen that the bulb was nearing the end of its life and must be replaced.
Fortunately I have the Circuit City extended warranty.
I called and within just a few days a serviceman came out and replaced the projection bulb.
The Result: No change in the picture, the green tint remains on all channels, so I'm awating the next service call. Under the service warranty they have the option to repair or replace this set. If indeed this is the light engine (optical block) which I suspect and its going to cost $1,000 or more I may be looking at a new set.
When it works this is a great TV, but I have had three Sonys now including two other standard CRT models and now this one joins them in the junk heap, the other two also bit the dust after just about two years. Is it time to give up on Sony?
I know they have a class action suit on a similar model for this same problem. Caveat emptor
Posted on Sep 22, 2008
Anonymous
SOURCE: 3 year old Sony KDS R50XBR1 suddenly no picture, no sound
MY SONY KDS-R50XDR1 TV ITS PLAYIN GREEN THERES NO BLUE HOW CAN I SOLVE THIS PROBLEM.
Posted on Feb 12, 2009
Anonymous
SOURCE: Sony Grand Wega KDF-E55A20 55 in. LCD rear projection HDTV
It is the lamp cover. There is a switch behind it and the post on the cover will slip off the switch. If this switch is not depressed, the tv will go off. No lamp light flashing or anything
Posted on Mar 13, 2009
adidas0068
SOURCE: sony kds-60a2000 has a green tint to picture
I have had the same problem for about 6 months, and never paid much attention to it. I also noticed that when trying to change the menu color, the colors do not show up correctly.
Now it seems to be getting worse, and so I started doing some research, starting with the Sony site. That is when I found out there is an extended warranty for the KDS series (50a2000, 55a2000, 60a2000, r60xbr2, and r70xbr2) TVs because of an optical block issue, until June 30, 2010, no matter when you bought the TV.
You can see the recall here: http://esupport.sony.com/US/perl/news-item.pl?news_id=277&mdl=KDS60A2000
It seems they are extending the warranty, but not doing a recall. In other words, they aren't telling anyone, but if you happen to find the information, they will replace the optical block, if necessary. The closest I could find to the green hue issue is a purple haze on the screen.
I don't know if this is the problem, but I have scheduled an appointment to have the optical block changed. I will repost after the optical block has been changed and inform whether this is the fix to the problem.
Either way, the optical block seems to be an issue and would get it replaced whether you need it or not.
Posted on Aug 23, 2009
Green tint on tv and picture randomly cuts out
Sounds like a Sony, if it uses a lamp the green cast is most likely the optical light engine in the set---major part.
Aug 28, 2012 | Televison & Video
I have a sony KDS-60A2020 that shows a green tint and can't be adjusted
There are 2 common causes of a Green Tinted Picture in Sony 60A2020 and other Sony LCD Rear Projection TVs:
  • HD cables from cable box or other source faulty or not tightly connected.
  • Optical Engine Failure.
    This link shows what some Sony Optical Engine Faults look like.
easyab
May 05, 2011 | Sony KDS-60A2020 60" HDTV
KDS 50A2020, Green Screen, took in to a Sony shop, they tell me it needs a new Wega Engine, cost is over $1000, is it worth it??? Do these go out in 4 years ?
Yes i have seen this a few times at the shop. Sometimes its a lose dvi cable. but 98 percent of the time a green screen like you describe is a faulty engine. I have seen this happen with less than a year. but the good thing then was the warrenty was still good. after 4 years sorry> is it worth it....... thats an opion, mine is time for a new television
Apr 22, 2011 | Sony KDS-50A2020 Television
Green cast to colors on sony KDS-50A2020
Hey there,
If you cannot fix this using the on-screen menu system (to adjust hue, etc), then this is a more serious problem.
It could either be that the lens has become distorted or in some other way altered.
Or it's time to replace the lamp.
I suggest speaking with the manufacturer or to someone where you purchased the tv, or to someone from a tv repair shop.
Good luck with you tv!
Mar 08, 2011 | Sony KDS-50A2020 Television
Tv picture is green
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 04, 2011 | Sony KDS-50A2020 Television
Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
May 29, 2009 | Sony KDS-50A2020 Television
Sonny tv-kds-50a2020
you need a new lamp sorry
shaun
Mar 27, 2009 | Sony KDS-50A2020 Television
Kds-50a2020 sony tv will not turn on
You may have luck in reading the blink code to find your problem at this link.
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Mike
Mar 22, 2009 | Sony KDS-50A2020 Television
Jul 31, 2008 | Sony KDS-50A2000 50" HDTV
Sony KDS-50A2020 Television Logo
195 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
