Question about Toshiba Satellite C655d-s5200 15.6" Screen Windows 7 Os
Why is my toshiba satellite c655d-s5200 screen is black and i can faintly see
My screen is black and i can faintly see the windows starup. How can i fix this problem?
  • Toshiba Master
  • 5,660 Answers
Okay. Got a bright flashlight, and some tape?
OH I'M JUST KIDDING!
Primer;
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED's.
Light Emitting Diode.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch. Average length is almost as long, as the LCD screen is in height,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 11 photos ]
A screen Inverter converts the power from the laptop, for the LCD screen.
The Toshiba Satellite C655d-s5200 uses LED's for the Backlight, and No screen Inverter,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~C655D-S5200/
Which narrows your problem down to two possibilities;
A) Problem with the video cable
B) Problem with the LCD screen.
I state LCD screen, because you won't be replacing the LED backlighting. You have to buy the entire LCD screen assembly, as shown in one example above.
(Example is shown for reference, not advertising. You may find a better deal from a reputable dealer, also)
Video Cable:
The Video Cable is attached to the motherboard, under right about at the number 6 key, on the Keyboard.
It then goes across to the Left Hinge, and up into the Display Assembly.
From there it goes to the back of the LCD screen.
From everyday normal opening, and closing of the laptop over time, the video cable may become pinched, and pulled on.
This can create a loose connection at the motherboard side, and/or LCD screen side.
It can also cause damage to the video cable. If the sheath of the video cable shows visual apparent signs of damage, the wires inside may be damaged also. (Stretched/Broken)
Laptop off, ALL power removed, (AC adapter {Charger}, and Battery), I suggest checking the motherboard side connection first.
A visual inspection will Not do. You need to physically see, if you can plug the motherboard side plug of the video cable, into the connector on the motherboard.
A loose connection that is not apparent to the ***** eye, is all it takes to have a problem.
You can click on any photo to enlarge,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-2.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-3.htm
Stop on Step 22. Access to the motherboard side of the video cable.
A word on the Keyboard Cable, and it's connector on the motherboard; (Steps 9, 10, and 11),
The Keyboard Cable stays with the Keyboard. It removes from the motherboard connector. The Keyboard Cable has NO plug, or connector on the motherboard end.
The Keyboard Cable is a FFC. Flat Flex Cable.
It has flat gold plated contact strips on the motherboard end.
The motherboard connector is a ZIF connector. Zero Insertion Force.
In Step 11 you can plainly see this connector.
Has a large white rectangular BODY on bottom.
The smaller rectangular shaped piece on top is the Locking Bar.
The Locking Bar does NOT completely remove from the Body.
If it does it is broken, and means motherboard replacement.
Hence why I am being so detailed.
I am sure you use great finesse, but wanted to advise you in advance of the 'danger'.
The Locking Bar is moved towards the LCD screen, and as advised about 1 millimeter. ( -> O <-)
There are Tabs on the Locking Bar. One on each side. Usual procedure is to use your thumbnails on these Tabs, and ease the Locking Bar forward.
Now gently tug on the Keyboard Cable. You may have to gently move it side, to side, to break the Keyboard Cable loose. They sometimes get stuck over time.
Pretty stiff? Better check to see if you have the Locking Bar fully unlocked.
The Keyboard Cable MUST go back in the same position, and through the same plastic Latches and Channels.
(As do all the cables, or you may pinch them, and also will not be able to get the laptop back together correctly again)
Make a mark on one side of the cable, (Away from the gold plated flat contact strips), and a matching mark on the ZIF connector of the motherboard, if you need to.
You can slip the Keyboard Cable back in, Ram Memory, DVD drive, and Battery, and reconnect the AC adapter, to see if this was the problem.
Still no?
Check the LCD screen side connector of the video cable. Is it tight?
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A665-A665D-A660-A660D/remove-replace-lcd-screen.htm
LCD screen connected, turn the laptop on.
Was this the problem?
No?
Even if there are no apparent signs of damage, you may wish to take the video cable down to the nearest 'Mom and pop' computer store, and ask them to check it for continuity. This way you can see if any wires are broken inside. (Labor charge may be free to $5)
(My thinking is if you go to a large computer repair shop, they are going to want to repair the laptop, or sell you an LCD screen, or a new laptop. "Oh that old thing? For 2995 I can put you in the seat of this baby!" )
Or since the video cable is very economical, you may wish to just replace it.
Just one example from a quick search,
http://www.ebay.com/itm/Toshiba-Satellite-C655D-6017B0265601-LCD-Video-Cable-Genuine-OEM-Laptop-Tested-/290753862740?pt=US_Video_Cables_Adapters&hash=item43b247dc54
[Black end on right is motherboard side, gold colored end on left is LCD screen side ]
Video Cable ruled out your problem is the LCD screen, or to be more specific, the LED backlighting.
Replace the LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Aug 29, 2012
5 Suggested Answers
DENNIS MITCHELL
  • 1003 Answers
SOURCE: toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
AvioriX is right your operating system is gone.
if u dont have restore disk get a windows xp program disk from walmart or target or office supply store and load operating system from it.(this will only load windows xp.) but will bring computer back up
Posted on Jan 15, 2008
clickman
Fadil Khan
  • 93 Answers
SOURCE: All for Toshiba Satellite P205-S6287 notebook
I am thinking that he just provided a set of drivers for this Laptop...
He simply put it there and said nothing...
Posted on Jul 22, 2008
SOURCE: Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Posted on Jul 26, 2008
parrotheadpc
Chip
  • 2600 Answers
SOURCE: black screen on toshiba satellite l35-s2174
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here:
http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 14, 2009
matt_g_walke
Matt Walker
  • 62 Answers
SOURCE: Toshiba satellite C655 laptop has black screen
Turn the computer off all of the way by holding in the power button until it shuts off.
Turn it back on and immediately start tapping the F8 key. It should bring you to a menu that has an option for going to "Last Known Good Configuration". Choose that option and see if it boots up.
If pressing F8 doesn't bring you to the menu - you may need to run diagnostics on the computer. To get to the diagnostics, attempt to boot to the Boot Menu by pressing F11 or F12 at the boot screen and see if it gives you the option to run diagnostics.
Posted on Nov 15, 2011
How can I fix black screen on Philips 42" LCD TV?
chances are it is cracked solder joint on internal board,
check link below, press the helpful button
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
Jan 24, 2016 | Philips 42PFL7422D 42 in. LCD TV
Black screen on startup
Try to refix the RAM and CMOS Battery.
Jul 04, 2014 | Dell Dimension 1100 PC Desktop
All i get is the acer intro screen and than screen goes black
Shine a torch at the screen when it goes black.
If you can see very faint windows, the back light faulty and new screen needed
Jan 20, 2014 | Acer Aspire Computers & Internet
Black screen
Your description of the fault indicates that the backlight is faulty. This Pc uses a LED backlight so will require an experienced repair technician to fix.
Jan 19, 2014 | Acer America Acer Aspire AZS600-UR308...
Powering up but black screen
backlight on screen doesnt work
Apr 05, 2012 | ASUS Computers & Internet
The desktop is blackscreen
When you say your desktop has a black screen does that mean after your computer boots up its black or even right when you turn it on you do not even see the the Bios screen.
I know you wrote desktop but are you just using that as a term for a a computer so Is is a laptop or desktop?
There are three possibilities,
1) Your screen died
2) Your graphics card died ( if its a desktop it usually an easy fix, if its a laptop most times its unfix-able )
3) if its a laptop can you see a very faint image? if so there is something called an inverter that can be replaced to fix that issue
Mar 03, 2011 | Computers & Internet
Picture goes black but still has sound
Use a strong light next to the screen and look for a faint image on the screen. If you see a faint picture, your backlight has a problem. Service shop time. Not a simple fix.
Mar 25, 2010 | Televison & Video
When I turn on my Mac laptop it does the starup noise and sound but the screen stays black. I plugged it and let it charge for about an hour and I even took the battery out and put it back in, but still...
check if it gives display to external moniter(u may use fn buttons in keyboard to toggle display)
if so
1. your lcd panel inverter card may be bad try replacing that
2. lcd panel back light may be bad try replacing lcd panel
3. vga section may be bad in mother board get expert help
observe esd precations
****aris****
Mar 11, 2010 | Apple MacBook Pro Notebook
Toshiba Satellite C655d-s5200 15.6" Screen Windows 7 Os Logo
867 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
