1 Check the fusing unit for proper installation and correct as necessary. 2 Check the connector between M3-PRCB CN2 for proper connection and correct as necessary. 3 Check the connector of M3 for proper drive coupling and correct as necessary. 4 PS37 I/O check, sensor check. 5 M3 operation check PRCB CN2-9 (REM) PRCB CN2-12 (LOCK) bizhub C554 22-J bizhub C454 21-J. 6. Replace M3. 7. Replace the fusing unit. 8. Replace PRCB.
Special firmware version (Web browser LK-101v3 support; Filename: GQQ-65 A1610Y0-F000-GQQ-65.exe)
Special firmware version GPQ-65 (Filename: A1610Y0-F000-GPQ-65.exe) Notes:
1. HDD Format will be necessary when CE301 or CED01 is displayed.
2. Please refer to attached Program Release Information prior to installing the firmware.
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
bizhub c284 standby and freeze
