Question about Samsung CLX-3175FN Color Laser All-in-One Printer
Scan/copy issue: horizontal lines and bulb red
The printing works fine but I have an issue with scanning and copying. Problems identified: 1) Rainbow colored horizontal lines appear on the pages; and 2) The scanning bulb first turns to different colors and then scans (moveds down and upwards) in red (instead of white normally). I am wondering whether the bulb is gone or perhaps there is an issue with the power supply. Any help will be greatly appreciated. Thank you.
Posted by Nathalie on
Lawrence Singapore
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
It's the scanner fluorescent lamp faulty, replace the scanner will solve the problem
Posted on Jul 26, 2017
3 Related Answers
Joe Fine
  • 628 Answers
SOURCE: Vertical line on page when scanning/faxing
Clean the scanner glass. You probably have some dirt or whiteout on it. Open up the top feeder and look at the narrow glass and you'll probably find it.
Posted on Mar 17, 2009
Anonymous
SOURCE: marks
i had the problem and fixed it. If it is the same problem as me, you need to make sure that you are cleaning the right peice of glass. The main bed is for putting the paper on there and scanning, but if you look to the left there is a small strip of glass that is used for scanning from the lid. There is probably only a very small dot of dirt or ink on the strip of glass. To help find the spot, look and see where the line comes out on the paper and then compair where it comes through the ****.
Posted on May 06, 2010
termistor
Patrascu nicolae
  • 85 Answers
SOURCE: Hello - I'm having problems with my Samsung
I think the scanner is dirty (and lamp glass inside), try to clean it, gently with a cloth (cotton), fine print that if if that ok
Posted on Apr 04, 2011
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
Print quality is batter but copy quality is not batter horizontal lines come in copy
Clean the glass for the scanner. If you get lines only when copying usually it is dirt. If your copier has both an adf and a flat glass for scanning, scan from both and compare the quality.
Dec 16, 2014 | Office Equipment & Supplies
Bizhub C652 has horizontal lines.
Print quality is good, b&w copy is good. When i make a color copy the machine makes blue lines or bink lines. This is a brand new c452.Scan to PC is ok, print its ok only copy. Lines are vertical.ea2265a7-6bf2-4ab0-abb0-94d103145c4c.jpeg
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
Panasonic DP-190 copier problem
The printer is obviously good but the scanning software used for making copies must have an issue. Did you check the scanning bulb for proper operation? If bulb is good then the issue lies with the scanning section of the machine,.
Aug 30, 2017 | Panasonic Workio DP-190 Multifunction...
I have an HP C5100 printer/copier/scanner. When we print to it the result is fine. However when we make a copy of something the copy prints out with random short horizontal lines. The location of the lines...
The problem will not be in the print head as you would have the problems when printing and copying . Do the lines appear when you are scanning. If so I would think that the problem could be in the optical unit. check that the unit is plugged in correctly. make sure that any covers above the glass on the optical unit are clean. I will check to see if a calibration can be done.
May 04, 2011 | Office Equipment & Supplies
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
My all in one printer/scanner is not scanning. prints and copies fine, but does not scan
Form your issue that you are able to print and copy but unable to scan it is very clear that it is a software issue. Copy and scan fuctions work this way.
Copy - completely related to hardware.
Scan - related to software
uninstall and reinstall the full version software from Hp for the operation system of your computer.
Aug 23, 2009 | HP DeskJet F4280 All In One Printer InkJet
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
Scanning Problems
I need some more information are the lines horizontal or vertical? Does it print fine from the computer? Does this problem only happen when you scan an item in and then print it or copying an item then print it? Also when you get this output do you have some of the text and lines or just lines?
Jan 08, 2008 | HP LaserJet 3050 All-In-One Printer
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
187 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
