Question about Juniper Trapeze Networks Mx-8 Wlc8r Mobility Exchange Wireless
How do I recover the enable password on my Trapeze mobility exchange mx-8. Or how do I do a factory reset?
The person that set the passwords is no longer with us and we need to do a factory reset or recover the passwords in order to set the configuration we need. We can connect with console connection.
Posted by Wayne on
terry778
    New Friend:
Hi Mate.
In case you still need to do this, or in case someone else stumbles on this problem and needs an answer, below is the the solution.
Connect to the MX device via console cable and recycle power.
Interrupt the boot process by pressing "q" followed by the "Enter" key when prompted.
at the boot> prompt enter the following command:
boot> boot OPT+=default (NOTE: This is case sensitive) and press "ENTER"
Presto, your devices boot with factory defaults.
Posted on Oct 26, 2012
  • John Feb 18, 2013
    Thanks for your post... However, when I press q followed by enter, the boot process continues to the login prompt. Tried numerous times, but it seems to ignore the keys pressed. Do you have any idea as to why?
Keeps telling me the ID and password do not match
If things really go south on your FireTV then you need to perform a hard reset, returning it into factory default mode. This will leave your FireTV just as if you bought it.All personal configuration, installed apps, games, passwords, etc. gone! but then, a hard reset will almost guarantee to recover into life your fireTV from non-working state.
You need to press RIGHT and BACK buttons for 10 seconds to initiate the Factory default reset.
Then you will have the original default username and password, which shold get you in to set it back up.
Oct 01, 2016 | Amazon Fire TV Stick
Lost my password
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password.Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router Reset for most routers with a reset button on the rear panelWrite down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
This applies to:
  • All NETGEAR devices
Sep 20, 2011 | NetGear WGR614 Wireless Router
I changed the default password, and I forgot it. How can reset the password, without lost the configuration?
There is no way to recover the password unless you reset it to factory defaults. This would mean losing your current configuration. I would try to guess everything you can possibly think of. If you still can't figure it out you need to reset to factory settings. To reset factory settings there is a button on the back of the router that says reset. Hold this down for 30 seconds and everything should be reset.
May 17, 2011 | Zonet (ZSR0104UP) Router
I forget my password , how to reset password ? please help me.
May 17, 2011 | Computers & Internet
I have forgot my router password, and can not add a wireless item
If you have forgotten your router password, the easiest thing to do is to reset your router to the factory default settings.To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Try this also:- u can recover it by simply connecting one of ur computer with the help of cable to router port 1, then open the browser and enter 192.168.1.1 in address bar .username ....... (blank)
password : admin
go to wireless ...then goto wireless security ... and there is ur security WPA key ...password.. make a not of it and try to connect it...
it would work without changing any personal settings...
Best luck try it out ..
Jan 07, 2011 | Acer Televison & Video
I need to locate and change my password
There is no way to recover the lost password However, you can reset the router to factory defaults and re-configure settings like password, network key etc. First, to reset the router to factory default setting, press the reset button at the back of the router.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer here to download the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | D-Link AirPlus DI-524 Wireless Router
I fortget the password plese tell how to get recover the password.
In case you have forgotten the password,
ALL YOU CAN DO IS TO RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory setting from the reset button on the back side of the router. It may be a push botton or else use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
HOPE IT HELPS...Let me know if you need any further assistance
CreativeTECH
Nov 15, 2010 | ASUS RTG32 Router
Reset my router password
Router password can be reset by pressing and holding down for 30 secs (reset is not a button , its a pin hole at the bottom of router )
before reset make sure u have all the information of your provider coz reset will bring down your router to default factory settings and then you have to reconfigure the router.
Oct 01, 2010 | Computers & Internet
How do you reset a password?
Easy, reset the router itself, should have a tiny pin hole in the back that has a button that you must compress, just google reseting your model.
If you have any problems let me know.
Apr 03, 2010 | NetGear DG834G Router
SPA 9000 VOIP - Need to log into system to change configuration.
No.
Try 'admin' and "blank".
Try "blank" and 'admin'.
Failing that, do the "reset to factory settings",
and then reconfigure your VOIP settings.
Apr 02, 2010 | Linksys Cisco SPA9000 VoIP Gateway - 1 x...
Juniper Trapeze Networks Mx-8 Wlc8r Mobility Exchange Wireless Logo
2,374 people viewed this question
Top Juniper Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Juniper Computer and Internet Expert? Answer questions, earn points and help others
