Pls help me
First, you need to make sure that your computer is equipped with a DVD drive and the drive should be able to write data in addition to reading data. Then you also need a DVD burning software tool to help you burn the dvd such as Leawo DVD Creator and Burnaware.
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file? Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file You can add more data if there is space on the DVD+R, but you can't overwrite it. You cannot overwrite this data. It's kind of like trying to use a permanent marker on the same spot of paper twice. CD-ROM Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM. 650 megabytes (MB) Highly compatible with most computers and devices. CD-R You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent. 650 MB and 700 MB You must close the session to read this disc in a different computer. Highly compatible with most computers and devices. CD-RW You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times. 650 MB Compatible with many computers and devices. DVD-ROM Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM. 4.7 gigabytes (GB) Highly compatible with most computers and devices. DVD-R You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent. 4.7 GB You must close the session to read this disc in a different computer. Highly compatible with most computers and devices. DVD+R You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent. 4.7 GB You must close the session to read this disc in a different computer. Compatible with many computers and devices. DVD-RW You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times. 4.7 GB You don't need to close the session to read this disc in another computer. Compatible with many computers and devices. DVD+RW You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times. 4.7 GB You don't need to close the session to read this disc in another computer. Compatible with many computers and devices. DVD-RAM You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times. 2.6 GB 4.7 GB 5.2 GB 9.4 GB DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices. hope this helps
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
