Lands Phones Logo
steven bennett Posted on Aug 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Programming the compact ics 2.0 - NorStar Lands Phones
curlycord
Level 2:
Scholar:
  • NorStar Expert 277 Answers
  • Posted on Oct 17, 2013
curlycord
NorStar Expert
Level 2:
Scholar:
Answers
277
Questions
Helped
45084
Points
448
1helpful
2answers
Charging solution
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
1helpful
Tda8172&stv9379whats difrent
Hello
TDA 8172 & STV 9379 are pin to pin compactable vertical output ICs, and are equivalents. to each other. Ok
PINS
1-Inverting Input
2-Supply voltage
3-Flyback generator
4-Ground
5-Output
6-Output stage supply
7-Non inverting input.
My f-450 2008 diesel has a continued problem.. signal work with out key and flasher unit stay on continuous while key off.
PATS Transceiver
The PATS transceiver is located under the steering column shroud and communicates with the PATS ignition key. During each vehicle start sequence, the PATS transceiver reads the PATS ignition key identification code and sends data to the IC. The IC validates the code, and if it is the correct code, will send a message to the PCM to ground the starter relay solenoid coil and to also allow the fuel injectors to operate.
PATS Operation
NOTE: If the IC or the PCM is being replaced (or both), the parameters must be reset in both modules or the vehicle will experience a PATS no-start. This will occur even if the vehicle is not equipped with PATS. PATS vehicles and non-PATS vehicles have parameters in the IC and the PCM and they must be reset whenever either (or both) module(s) is (are) replaced. Refer to Passive Anti-Theft System (PATS) Parameter Reset in this section.
The PATS function is controlled by the IC. When the PATS key is turned to the ON or START position, the IC initiates the key interrogation sequence by sending a voltage signal to the PATS transceiver. The transceiver then uses its antenna to bounce a signal off the transponder in the PATS key. This process "reads" the PATS key identification code and sends the key identification code back to the IC, which interprets it and determines if it matches one of the stored key codes. If it does match one of the stored key codes, the IC will send a message to the PCM to ground the starter relay solenoid coil and to also allow the fuel injectors to operate. If it does not match one of the stored key codes, or it is only a partial key read or no key read, the IC will send a message to the PCM to not ground the starter relay solenoid coil and not allow fuel injector operation. The anti-theft indicator in the IC will flash (or may glow steadily) and the IC will store one or more DTCs. All elements of PATS must be functional before the vehicle will start. If any of the components are not working correctly, the vehicle will not start. If the IC must be replaced for any reason (PATS concerns or IC concerns), the PATS keys must also be programmed into the new IC. Refer to Key Programming Using Diagnostic Equipment in this section.
PATS disables the vehicle from starting if there is:
  • a damaged PATS key.
  • a non-programmed PATS key.
  • a non-PATS key (key has no electronics).
  • damaged wiring.
  • a damaged transceiver.
  • a damaged IC.
  • failed parameters between the IC and the PCM.
PATS Parameter Identification (PIDs)
Monitoring the PATS PIDs in the IC can be very useful in determining which diagnostic steps to follow. Viewing the MASTERKEY (verifies if the key is programmed) PID (with both keys) will determine if the key is a programmed key and will also prove out the transceiver, circuitry and the IC. A master key is any key that is programmed into the IC (the MASTERKEY PID must display PRESNT). If the MASTERKEY PID reads NOTPREST, it may mean the key in the ignition lock cylinder is not programmed, is not a PATS key, is damaged or the transceiver, circuitry or IC may be at fault.
Viewing the MIN_KEY (minimum number of keys) PID (this PID does not change) indicates the minimum number of keys that must be programmed into the IC. There must be at least 2 keys programmed into the IC in this type of PATS before the vehicle will start.
Viewing the N_KEYCODE (number of keys programmed) PID will determines if the minimum number of keys have been programmed into the IC. If the N_KEYCODE PID reads 0 or 1, additional key(s) will need to be programmed into the IC in order to meet the minimum of 2 keys. If the N_KEYCODE PID reads 0 or 1, and the MASTERKEY PID reads NOTPREST, that particular key must be programmed into the IC. If the N_KEYCODE PID reads 1, and the MASTERKEY PID reads PRESNT, that particular key is already programmed into the IC.
If the IC was replaced, the parameters in the IC, then the parameters in the PCM will need to be reset. When the parameters in the IC are reset, that clears (erases) the PCM ID from the IC. A parameter reset of the PCM will send a PCM ID to the IC that is necessary for the system to operate. Make sure to make 3-5 attempts to start the vehicle for 3-5 seconds each before attempting more procedures. The extra key cycles are necessary for the PCM ID to be sent (by the PCM) and then stored by the IC. If only a PCM parameter reset occurs, the IC may encounter 2 PCM IDs (the original one and the new one) and may cause a PATS-related no-start. If a PCM parameter reset occurs first, then the IC parameter reset occurs, there will be no PCM ID stored in the IC, and a PATS-related no-start may occur. Carry out the IC parameter reset first, then the PCM parameter reset next. If the PCMID PID reads STORED, the IC has a PCM ID stored. If it reads NOTSTRD, a parameter reset of the PCM may resolve this issue. If the PCMID PID reads STORED, the PCMVER (the PCM ID has been verified) PID will read YES.
If the PATSENABL PID reads DISABLE, and the N_KEYCODE PID reads 2 or more and the MASTERKEY PID reads PRESNT, the IC and the PCM will need to have their parameters reset.
If the PATSENABL PID reads DISABLE, and the N_KEYCODE PID reads 1 and the MASTERKEY PID reads PRESNT, or if the N_KEYCODE PID reads 0 and the MASTERKEY PID reads NOTPRESNT, a minimum of 2 keys will need to be programmed into the IC. Refer to Key Programming Using Diagnostic Equipment in this section.
If the MASTERKEY continues to read NOTPRESNT after programming, this may indicate a defective key. The SPAREKEY (spare key) PID is defaulted to ENABLE. With the SPAREKEY PID displaying ENABLE, the IC will accept more than 2 keys (up to a maximum of 8) being programmed into the IC. Refer to Key Programming Using Two Programmed Keys in this section. It can be toggled to DISABL if the customer does not want any more than 2 keys programmed into the IC. Refer to Key Programming Switch State Control in this section. This switch state control does not affect the Key Programming Using Diagnostic Equipment procedure.
In summary for the IC PATS PIDs and their correct state in order for the vehicle to start:
  • N_KEYCODE must read 2 or more
  • MASTERKEY must read PRESNT
  • PCMID must read STORED
  • PATSENABL must read ENABLE
  • PCMVER must read YES
2answers
Even if i connected the charger its not charging
First Option:
Second Option:
Jan 03, 2011 • Nokia 7610
Installed this NT9K08AD03 where a NT8B30AD03 was and the new phone does not work. Meridian Compact ICS 2.0
The M2008 set (NT9K08AD03) doesn't work on a CICS system. It works with the Meridian PBX systems. The type of sets that work with a Compact ICS system are M 7100, 7208, 7310, 7324 and T 7100, 7208, 7316, 7316e as well as some of thier cordless sets.
2answers
My phone is not charging up when I plug it into the charger
First Option:
Secend Option:
2helpful
NorStar ICS Caller ID Upgrade
Yes, this is correct. install the co card with cid and you should be fine.
Dan
5helpful
Time on phone
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If asked for a password enter the same 2 3 6 4 6.
If that doesn't work you may have the newer Compact ICS or the Modulur 0x32 control unit wish will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the (next) button until you see what you want to change. Then press (show),then (change) if you want to change it. If you pass it, just press (back)
Example: To change the Time & Date Press (next) until you see Time & Date. Then (show) Then (change) Then (change) again, change it if you need to, Then (next) again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press (next) until you come to the (Hour). Then Change it. Then press release (RLs) when your done. To get out of programming, just press the release button (RLs).
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
