It started when the light and LEDs for the ice dispenser would go out when trying to get ice. It would not dispense. This morning, the Fridge was making clikcing sounds like the compressor was trying to come on. It seems like it doesn't have enough power to operate. The breaker is good and I cycled it this morning.
SOURCE: Compaq Evo N600c won't boot up
Check voltage of AC adapter with voltmeter and make sure voltage matchs the output noted on the adapter and the bottom of the laptop.
Make sure the voltage is steady and not jumping all over. If you have another adapter with the same output voltage and AMPs equal to or greater than the required AMPs, try that. This will rule out the adapter if you still have the same problem.
SOURCE: It's dead! I switch it on and nothing happens
remove battery, plug the power, turn it on. your battery may have completely discharged that your laptop is having hard time charging it and powering the system at the same time,
SOURCE: My AspireOne ZG5 Does not
if there is no diaplay ....u need to update the bios ...download zip file from this site http://macles.blogspot.com/p/acer-aspire-one-bios.html exteact in formated USB drive... plug the charger keep press FN+ESC button and trun on laptop u can see light flashing when light gose off u can relase button .. and wait for 5 min .. system will restat and u can see display... thanks
SOURCE: I start my computer with
Have you Checked the power Supply? it sounds like the power supplyhas gone bad.
SOURCE: I can't unmute my speakers.
It seems to me that the problem might be a driver issue. Try to restart it, if the problem remains, go to control panel, disable the driver, reboot again and return to control panel and enable the driver again. That might work.
