Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Water will not drain away
Will wash wont drain away
Posted by Linda Allen on
Douglas Cobb
Why has my machine not drained or Spun.
Cant be 100% but could be overloaded, turn off, set dial / program to spin and try again, may need several goes to empty.
Jan 13, 2016 | Washing Machines
Not drain water
This video will show you how to clean the pump and how to find the fault on a washing machine that won't drain or empty the water away on Bosch, Neff or Siemens. Please remember to subscribe to our YouTube channel for all appliance tutorials
a thumbs rating is appreciated for answering your free question.
Jun 02, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water wont drain away when in its final spin,and i have have fitted a new drain pump
If you changed the drain pump I would check the following things:
1) Is the machine actually sending power to the pump to turn it on. You can check this by using a volt meter and with the machine open disconnect the power to the pump and place machine in drain and test to see if voltaqge is being sent to the pump
2) Check your lines and the drain itself. Any blockages could prevent draining.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | Hotpoint Washing Machines
My zanussi FJS1025W washing machine is showing the error code E20 and it wont let me spin or drain the water away. I have cleaned all the filter but still it wont do anything other than take in the water...
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out.
If still the problem persists then the problem is with the draining pump.The pump is not pumping out the water.Check the pump impeller it may got stuck due to some obstacles.Replace it and this wont come again.
Thank You
Sep 09, 2010 | Washing Machines
It washes the dishes but the water wont go away i have cleaned the filter and surrounding area but water wont go away any ideas please thanks
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 05, 2010 | Indesit Dishwashers
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
The water is not draining away. Hotpoint WD63
filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
Jan 04, 2010 | Hotpoint Aquarius WD63 Front Load...
ALL FUNCTIONS OF WASH CYCLE WORK EXCEPT WATER WONT DRAIN AND SPIN CYCLE WONT WORK,
Pump is blocked or shot
Pressure switch made telling the machine it is full of water hence no spin.
Drop hose into bucket to drain the water off and the machine should spin, you may be better dragging the washer to an outside door and let all of the water run away at once .
Make sure that the drain hose is unclipped from the back of the machine so that the bottom of the hose is as low as you can get it
Jun 25, 2009 | Roper RAS8445KQ Top Load Washer
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
349 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Mike
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
