Printer keeps printing from memory how do i stop it printing and clear the memory
SOURCE: printer won't delete job
First goto Start>run>type services.msc then find print spooler then stop it ...
Goto Start>run>type spool > goto printer and delete all files ...
at last goto Start>run>type services.msc then find print spooler then start it ...
SOURCE: Print faxes in memory on a Lexmark X5470 All-in-One
I solved my problem by powering off, which I knew would lose the faxes in memory. However, I decided to have the faxes re-sent. As soon as I get time, I will address this issue with Lexmark. It seems incomprehensible to me that Lexmark does not provide instructions on how to do this.
Thank you for your interest. This simple question does not warrant a team to figure out--it is a manufacturer's responsibility.
SOURCE: lexmark x342n
A 902 Service Engine Software error indicates a failure in the engine board software, power off clear print que on pc print driver then power up if problem persisits see this link
http://www.marketpoint.com/article.cfm?id=119
SOURCE: lexmark x5470 wont print fax in memory
Try this from Lexmark support site, it should fix the issue.
http://support.lexmark.com:80/perl/support/support.cgi?relevance=1&ccs=229:1:0:549:0:0&mode=DOCS&doctype=KB&term=fax&docid=ENUS26838
SOURCE: My Office Printer Lexmark X342n is not accepting any command
Upgrade firmware, sounds like old firmware used. Kinda basic problem with fax usage.
Contact local lexmark for firmware upgrade
That should fix the problem
