Panasonic PV-GS31 Mini DV Digital Camcorder Logo
A
Anonymous Posted on Aug 28, 2012
How to download video from miniDV tapes - Panasonic PV-GS31 Mini DV Digital Camcorder
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Aug 28, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
362
Points
13
Actually, for the video-grabbing I'd use torch browser- it's fast and allows you to download videos really easily.
1 Related Answer
TIPS72
DUSHYANT SINGH
  • 369 Answers
  • Posted on Dec 05, 2010
SOURCE: How can I download my
For the video you can use windows movie maker to grab the videos and if its hard drive you can directly connect them to your laptop through usb and copy past all the pictures to you internal hard drive
Thanks
Hi! my sony dcr-trv265e can play the tapes via the video and tv but when i re-record over them its just a blank blank screen? so i need anothe tape or can i record over old tapes?
Sony and the other media suppliers do not recommend re-recording over any digital tapes, including MiniDV. Re using tapes can lead to dropouts and errors after only a few times. With MiniDV prices so inexpensive these days (in the grand scheme of things), is there any reason NOT to use new tape? Also, many companies keep all their MiniDV tapes as a kind of stock footage archive. You never know when you might need a shot that you have already filmed, and it saves considerable time and money to pick the tape off the shelf.
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
I have the panasonic minidv can you record videos without the min
Your Camcorder supports video recording using the Tape only. However, you can record images (only) using the SD Card.
HOW DO I DELETE RECORDS FROM JVC -D740EK VIDEO CAMERA?
Since the JVC GR-D740EK is a european miniDV camcorder with no embedded memory nor memory card slot, I would assume that your talking about erasing or recording over your miniDV tapes. You can simply do so by sliding the the erase protection tab on your miniDV tape towards "record" and you can begin to record you movies. Prerecorded tapes cannot be deleted and used as "new" or bare (having no recording on it).
Downloading to computer to burn to a dvd
I have a zr300. You need a firewire connection and a firewire cable to download the contents of your minidv tape for burning. You can not do that with a usb cable. USB cable can only download photos and videos from your memory card not from the tape.
Samsung SCD-5000 miniDV tape deck problem
Hi, I have a SCD 5000 Samsung camera. The video plays and records. But the camera side does not show in the video screen. HELP me
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
