Question about NEC Dterm Series I Dtr-8d-1 / 780039 Black 8 Button Spe
My phone is not ringing? I can see the red light blinking though.
Posted by Noemi Montenegro on
  • Anonymous Mar 26, 2014
    Phone will not ring
Johny
  • 540 Answers
Please check the volume settings or switch, it may be set on mute.
Posted on Aug 28, 2012
The red light is blinking and when i turn it on it goes to green for a few seconds and then beeps and blinks red again.
You have "The red ring of death" If 1 corner is blinking: Turn it of and wait a few days for it to cool off. If 2 corners are blinking: Do the same, but check after 3-5 days to see if it works. If 3 corners are blinking: You HAVE to see a xbox repairer, because you can't wait after 3 rings. Saddly, a complete ring of red: You can't do anything about it, it can't be repaired, but check the power wire and reattach it, there's a little glitch where if you loosen the wire, it does that. Good luck!
The phone kx-dt333 does not ring out loud when there is an incoming call. A red light appears however no sound is made even though the volume is up on full.
The Panasonic TDA-50g comes out of the box with one ringing phone, extension 101. All the other phones light a solid red light when 101 rings. Is that what your system is doing?
Unless you have access to programming or a Maintenance Console and have intimate knowledge of system programs 623 and 624, you need to let your installer or dealer program ICD groups.
That programming is beyond the scope of a free forum.
Carl
How can I set my uniden (DECT 6.0) to ring 5 times before going to message? How can I get rid of the red blinking light on all my phones?
What model Uniden DECT 6.0 system?
As for the blinking light, you apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
I have a few KX-T7453s that will not ring. They work and I can hear pages on them and can see the lights blinking when a call comes in. The ringing volume is all the way up though. What am I missing?
Programming. The ring on a TD system is controlled by system programs 603-604 or maybe in 407-408. Exact instructions are contained in the Programming Manual for the TD systems.
Carl
3 blinking red lights
u my friend hav the 3 red rings it just means that u need 2 let ur xbox rest 4ahale ur lucky its not tha ring of death
1helpful
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
1helpful
Sony W580i won't turn on. Blinking red light.
It turns out i found a solution to my problem. All you need to do is wait a few days and every day try turning it on several times. Mine turned on with 2% power. If you don't see the red light blinking then you probably need to charge it up then turn it on.
Blinking green
You may have the battery light reminder on...so you will need to take it off
Night button and incoming calls
The programs involved with you ringing are 81 ( no light or Day Mode ), 84 ( blinking red light or Day 2 Mode ), and 87 ( solid red light or Night Mode ). To change the ringing assignments you need to know the port numbers of the phones you want to ring or not ring. You can do this by pressing DN/ICM dialing # 4 0 2 at each phone, the diaplay will show the physical and logical port numbers. These numbers will be used to turn on or off the aaociated lamps within the above programs. Do you have anyone on staff that understands the system programming ? Let me know ...Mike
LINE 3 RINGS ON ONE PHONE- AND DOES NOT RING ON THE OTHER 3...
You will have to get into the programming mode and change Memory Block 4-01 for the port of each phone you want to ring. The corresponding light for the button is OFF for no ring, GREEN for ringing, and RED for delayed ringing.
NEC Dterm Series I Dtr-8d-1 / 780039 Black 8 Button Spe Logo
Top NEC Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
