I tried to watch my videos from the usb on the jmb 22 led tv and all video formats are invalid or not supported. What should I do?
SOURCE: cannot play video games downloaded
I was getting the same problem with my lcd tv. I was using a DVI to hdmi cable to connect the pc to the tv. I switched to a vga cable and I was able to finally get into the game. Once you get into the game make sure you change all the video settings to be compatible with your tv i.e. resolution for a 720p set should be 1366x768 on the game resolution, and you should also change the refresh rate to 60hz in the game if that is the max. on your tv.
Once you do this, you can then put your hdmi cable back in and get into the game. Every game I install I have to first run using the vga cable, and then switch to HDMI.
SOURCE: no video display,
PS3 is The amazing device by sony but it has some common problems like no video display,sound problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
SOURCE: My 42LG50 won't accept the 1080p output from my PS3 Plz help.
Most PS3 games do not support 1080p, so if u have a 1080p supporting game, only then can u do it.
SOURCE: My I9 won't play any video file and i've tried MP4
You need set the right resolution for ur I9 ... Just try Daniusoft video converter, it is already optimized for output setting for mobile phone. You could convert various video to I9 for watching with it...
SOURCE: .mkv doesnt play on LED:UA32C5000 but plays on LCD:LA32C530
Hi
I am also facing similar problem with recently purchased LED 46" P6200. Do not know the reason? Does anyone has any idea why it is so? Thanks
