Question about HP LaserJet 4730 MFP Printer
Color laserjet 4730 initializing scanner error message
Color laserjet 4730 come up with initializing scanner error message when you swtch on
5 Related Answers
Anonymous
SOURCE: HP LaserJet 3030 Message: Scanning error cannot connect
I had the same problem on XP and Vista and it turns out that if your don't have the HP Toolbox Running/starting up with pc this caused my problem. Once I lunched it to startup with I am able to scan using the Scan To Button on my Scanner.
-Cepedare
Posted on Dec 20, 2008
Anonymous
SOURCE: error 51.23 on HP 3600 color laserjet printer
Error 51.23 on HP 3600 color laserjet printer
Posted on Dec 25, 2008
Anonymous
SOURCE: Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
Posted on May 14, 2009
Duke Bells
  • 131 Answers
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Posted on Feb 23, 2010
sandimcp
Sandra Lloyd
SOURCE: Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
Posted on Sep 01, 2010
Error code 51.23
From the HP manual.
51.XX Error, Turn off then on
Description
The product has experienced an internal hardware error.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product on.
If the message persists contact HP support.
From PrinterTechs.com
51.X PRINTER ERROR
A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
Oct 08, 2016 | HP LaserJet Pro 400 color M451dn - Printer...
I hp.color laserjet 4730 full with scan I maen twian drive of it
Hi Chimezie,
If you are looking the the drivers for this model, you may download them from here:
HP Color LaserJet 4730 Multifunction Printer
Sep 07, 2016 | HP LaserJet Office Equipment & Supplies
HP Color Laserjet 4730 MFP scanner not initializing
open the scanner's glass cover ,,, there is a white sensor on the backside of the glass ,,, clean it with a little wet fabric ,,, then change the scanner unit's place to be exactly under the sensor ,,, close the cover ,,, turn on the power ,,, and give me a good rate ,,, :)
Sep 22, 2013 | Office Equipment & Supplies
HP Color Laserjet CM4730 Scanner Not Initializing
I had an issue similar to this and it was fixed by replacing the memory dimm on the bottom of the formatter.
Nov 17, 2011 | HP LaserJet 4730 MFP Printer
My HP LaserJet P3005n, is not working properly whenever I want to print it initializes and then show Error 52 message.
52.00 ERROR
A scanner motor error has occurred.
Scanner motor rotation is verified at the initialization of a print job.
1. Verify that the scanner motor connector and the ribbon cable from the ECU are firmly seated on the laser/scanner assembly.
2. Verify that the scanner motor connector is firmly seated in connector J402 on the ECU. You might have to remove the main cooling fan to see this connection.
3. Verify that the ribbon cable installed in connector J403 on the ECU is fully seated.You must remove the ECU in order to verify this connection.
4. If the message persists, replace the laser/scanner assembly.
Jul 26, 2011 | HP LaserJet P3005 Printer
Message error 51.23 on hp color laserjet cm2320nf
The 51 refers to a laser scanner error. The 23 refers to the yellow laser scanner.
Turn power off. wait 30 seconds. Power up and monitor. If the error reoccurs, your printer
is going to need a DC Controller.
Mar 02, 2011 | HP Laserjet CM2320nf All-In-One Color...
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
Aug 12, 2008 | HP LaserJet 3600n Printer
HP LaserJet 4730 MFP Printer Logo
816 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
