Fisher and Paykel DD60DCW6 Dishwasher Logo
Question about Fisher and Paykel DD60DCW6 Dishwasher
How to remove the handle off a fisher & paykel dishwasher DD60DCW6
The strip on top of the drawer snapped off. We have replaced the part but it's the whole 'top part' of the dishwasher. How do I get the old one off?
5 Related Answers
Anonymous
  • 413 Answers
SOURCE: Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Posted on Jun 08, 2008
Anonymous
SOURCE: dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Posted on Jan 01, 2009
Anonymous
  • 232 Answers
SOURCE: My fisher and paykel nautilus dishwasher isn't draining properly
remove strainers and clean and try again
Posted on Dec 27, 2009
Anonymous
SOURCE: Fisher & Paykel Dishwasher DW60CSX1
I have a dishwasher - "Soft Touch" which seems to be stuck on F1. This occured in the middle of the night and although turning off at wall cannot get it off this setting
Posted on Aug 29, 2010
Anonymous
  • 8197 Answers
SOURCE: Help, need a user manual
You can get the manual on the link below.
http://www.scribd.com/doc/6462163/DD601V2-Manual
Posted on Jan 23, 2011
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
I have a small piece of plastic stuck in the drain hose of my fisher paykel top dish washer drawer. I have tried cable wire but it does not budge after about 3 inches. Is there a way to remove the bottom...
There are two pieces of drain house in a double drawer FP dishwasher. The one from top drawer, the one from bottom drawer which then merge into a U adapter before hoing as a single hose into the kitchen sink.
I don't think anything can be achieved by taking the bottom drawer out. If the obstruction is in the top drawer drain hose, you will have to take that out and turn it over and disengage the hose from the bottom of the sump. Your best bet is to refer to this install guide on removing the drawers. Refer page 7 step 2.
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Use reverse method to put it back in. Make sure you keep a stool nearby to hold the drawer in place and not let it fall on the floor. The cables and hoses are very tight and need care when handling.
Fisher & Paykel DD601v2 dishwasher
here's the manual..
i did not read thru the whole thing but there are quite a few removal items that i'm sure will lead you to drawer removal.
Hope this helps you.
https://www.scribd.com/doc/6462163/DD601V2-Manual
2answers
Touch sensitive buttons on my F&P dishdrawer dishwasher Model dd60dcw6 have stopped working. They are stuck on one wash.
If water is in the bubble, you will not be able to change cycle. Open drawer, hit power, close drawer, reopen drawer and try again. If water is in bubble your your finger is wet, the board cannot sense your finger. This button is not s button, its a sensor, just slid your finger across, its designed to detect your current in your body, not the touch of a finger.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
5helpful
3answers
Dishwasher beeping and displaying F1 on screen. HELP!!
F1 error means that the flood switch has been activated. To reset the flood switch you need to remove the bottom dish drawer to be able to access the reset buttons. To remove the drawer you press in the rectangle buttons and slide them back under the drawer, they are located right behind the front panel at the bottom of the drawer. It may help to have someone help hold the drawer for you. Once they are slid back all the way place the bottom drawer on the floor to the left side of the washer as you look at it. This will give you the access you need. Lie down on the floor so you can see in the bottom. There you will see a white coloured plastic box on each side, one is for the top drawer the other is for the bottom drawer. Make sure the power is off to the dishwasher. Place your finger underneath the box and you will feel a small pin/lever. This is attached to the magnetic flood switch and resets it when you click it one way and then the other. Once you have done this turn the machine back on before you put in the bottom drawer as if it does not work then you will need to activate it maybe a couple of times. Once the F1 alarm disappears you are good to go. Place the drawer back in the opposite way to removal. Slide one rack forward and rest the drawer on it. Then slide the other side out and it will snap lock into position.
2helpful
I brought a new face plate for the handle of my F&P dishwasher but can't work out how to remove the old one?
Pull the plastic screw on each side of the drawer with a nose plier. This will loosen the front cover and allow you to lift the top plate along with the handle. Replace the handle and put back the front plate and the front cover. Finally put the 2 screws back.
4helpful
How do i fix an F5 error code on a Fisher & Paykel Dishdraw DS605. I have turned the power off but the error keeps returning?
I am assuming you have the DD605 double drawer dishwasher. Is the problem F5 on both drawers or just one?
F5 code involves the drawer lid seal and will need a bit of effort to check and fix.
Take the drawer out and inspect the inside of the top panel for a black rubber strip. If it is broken or not responding to up down movement then it needs to be replaced. In addition the actuator motors on each side that drive the seal could be faulty.
If you are not comfortable with repairing slightly complex apliances then you may have to call the technician.
Open Questions:
Top Fisher Dishwashers Experts
vince
Paul
NOEL
NOEL
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
