Question about Haier HVT12ABS Compact Wine Cooler
Wine cooler drain plugged how to clean - Haier HVT12ABS Compact Wine Cooler
Posted by braytanya on
evelyn neeley
    New Friend:
Try running a pipe cleaner through it
Posted on Aug 27, 2012
2 Related Answers
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
mrbobfixit
Robert DeStevens
  • 259 Answers
SOURCE: Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Posted on Jun 14, 2010
How should I clean my wine cooler?
You should follow my exact instructions in order to clean your wine cooler properly.
1. Unplug your cooler and remove all items from it.
2. Clean the inside surfaces with a mild cleaner (I recommend you to mix water and soda).
3. Clean the wire shelves.
4. Clean the wooden shelves.
5. Wash the outside of the cooler.
6. Dry any wet part with a soft cloth.
Aug 14, 2012 | Furniture
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
Unplugged the wine cooler to move for painting. When we re-plugged it in it was not working at all. Took off the back and cleaned out any dust from the fan. All of the wires look like they are in place....
First check your breakers. Sometimes re plugging an item can cause a surge and pop the breaker. Maybe some paint might have gotten in the outlet and preventing a clean contact. If all fails, try plugging in the unit in another outlet to see if the problem lies within the outlet or the wine cooler.
Mar 21, 2011 | Cuisinart CWC-1200 Wine Cooler
Haier wine cooler won't cool
Does the unit cool at all? If it is running and not cooling properly, check and clean the condenser coils on the back of the cooler.
Jan 25, 2011 | Haier BC112G Wine Cooler
Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
Jul 16, 2010 | Danby DWC283BLS Wine Cooler
Doesn't cool and i am assuming that means the condensor. How much to fix. it is two years old but with very little use , looks brand new.
clean coils front and back....clean drain oil fan motor...take cover off relay...clean plugs and pins( from oxide)...if it starts hard get a har d start kit for compressor
Aug 28, 2009 | Danby Silhouette DWC512BL Wine Cooler
Fan runs, but no cooling occurs;
clean both coils(fins)and drain use non-detergent non additive oil(not motor car oil) for fan motor take cover off compressor relay and inspect wires(clean plugs and pins of oxide) you may need a hard start kit if it has a hard time starting
Aug 24, 2009 | Breezaire WKE 6000 Wine Cooler
Water seeping out the bottom of my wine cooler
there should be a drain pan that you will periodically remove. Condensate (water) is a normal byproduct of all refrigeration devices. Also look for a drain fitting that you can run to a waste line.
Nov 25, 2008 | U-Line Wine Captain (2015WC) Wine Cooler
U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
Haier HVT12ABS Compact Wine Cooler Logo
246 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
