No longer self-propelled
SOURCE: Kirby Ultimate G self propelled drive unit locked up
If you're still looking for a shop to fix your Kirby, try www.sparesaver.com as they have a Kirby repair centre.
SOURCE: Self propelled function
There are few things that may have gone wrong:
First thing to check is if when pushing pedal it moves gears located on the rear axle (you will have to take cover shell off to see that)
If that works fine then primary belt may be broken (see it here). Then just replace entire set to make sure that belt type matches gears
Last - the most expensive problem - the main transmission belt within transmission is broken (then I would recommend replacing entire transmission)
SOURCE: g-4 Kirby self propel unit works in reverse but not foward
Jon,
Here is a helpful link to use to adjust the tranny. About a 7 on the difficulty level.
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
