This phone has been blocked to make outgoing calls, and we'd like to unlock it. I've search in the instruction books without any success.
SOURCE: Our office has 13 phones
You will have to go into system programming, under sets, line appearances. You will need to set the lines on the phones to appear and ring, not just appear.
SOURCE: call forwarding for NorStar m7310
You have to know how to get into programming, and it depends on the type of telephone lines you have... if you have regular analog lines, on a out bound call transfer there is going to be line degragation. Meaning that the outgoing call is not going to be of the best quality.
Secondly, you have to see how many telephone lines you have, if you have 3 analog trunks, with a call forwarding to a cell phone, you will be using up 2 lines... 1 incoming and 1 outgoing to your cell. This leaves 1 trunk for incoming or outgoing callers.
SOURCE: What is a Norstar Overlay Template?
right top Show
right bottom Next
left top Heading
left bottom Back
Actually, even as a technician, you will never know the origonal password.
But you can get in to reset the existing password back to 0 0 0 0.
There are a couple of steps; depending on your voicemail system, voicemail's are done differently, but try this first.
got to a M7310 set
-> dial FEATURE 9 8 3
-> password: 1 0 2 0 0 0 0
-> you should now see ADMIN and under that MBOX, AA, OTHR
press MBOX
-> press CHNG
-> dial the extension of the phones that you need changed
-> you should now see PASSWORD and under it RESET, press RESET (This resets the mailbox back to 4- zero's)
-> hit the * to back up and repeat fopr all the other extensions.
-> hit RLS after all is done and voila... you have now changed those passwords to those mailboxes.
Now when the new users dial F981 at their desks, and dial 0 0 0 0 the first prompt they get is pleasde change password.
SOURCE: I have a Norstar Meridian with M7310 phones. When
sounds like your telephones not programmed for handsfree.
Programming is done on 7310, 7324 and 7316 type sets.Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the release key when finished
