Whirlpool AKZ159IX Oven Logo
A
Anonymous Posted on Aug 27, 2012
Power cut and now my whirlpool akz451 will not heat up
I have reset the clock, the light is working but the oven will not heat up
Jorgie the appliance guy
Level 3:
Top Expert:
  • Whirlpool Master 5,639 Answers
  • Posted on Jan 03, 2017
Whirlpool Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1521769
Points
32630
Http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
4.Repeat the step above for the terminals "L2" and "H2".
5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
5 Related Answers
Anonymous
  • 833 Answers
  • Posted on Dec 07, 2007
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 12, 2008
SOURCE: Whirlpool AKZ451 oven not working properly
If the fan is still working ,then you need a new oven element fitting, it will have blown, there by causing trip to operate.
Plz rate this solution .
Thanks.
JohnGD
  • Posted on Dec 24, 2008
SOURCE: whirlpool oven
Press the botton between the two control knobs and hold for a few seconds.
Anonymous
  • 18 Answers
  • Posted on May 17, 2009
SOURCE: Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
could be a blown element if not it could be a safety cut out or the stat
Paul Davies
  • 157 Answers
  • Posted on Mar 09, 2010
SOURCE: i have a whirlpool akz451 oven.the oven does not
element around fan
I have whirlpool oven akz451/ix/01. My element is square when I look for a new one they are all round ?? Will this work in my cooker ??
whirlpool service center /agent will have a correct element for your unit
the shape is probably for a more even heat distribution in the oven as it will cover the floor/ top area of the oven better
Oven on my akz451 dont work but grill works and fan and lights working
Check clock It could have the oven off waiting for time. Turn it to manual
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
3helpful
My AKZ451 oven has stopped heating up. The grill, light, fan is working fine.
You need to replace the oven element, located at the rear of the oven compartment, behind a removeable cover.
My Whirlpool AKZ451/IX/01 will not heat up correctly
I can fix this for you. Where are you residing please? Thanks David. "The Famous Forry'
I have a Whirlpool AKZ451 built in oven that is not reaching temperature. The oven element appears to be working, could this problem be the oven temp sensor?
yes, or the oven control itself,make sure also to closely inspect the element itself for any "HOT-SPOTS" where its getting a high resistance area and not passing all the current needed to heat the element
Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
9helpful
Thanks.
2answers
Problem with our oven
how to fit a heating eliment to a whirlpool akz451/1x/01 oven please
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
