For sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
SOURCE: SGH-A867 Samsung unlock code. I am trying to
USE ALL * AND # INCLUDED WITH CODE .PLACE DIFFERENT SIM CARD IN PHONE ANY OTHER THAN ORIGINAL DONT WORRY THE CARD WONT BE HARMED READY LETS TRY?ENTER THIS CODE
*7465625*638*00000000*00000000#HIT END KEY ONCE THEN ENTER *2767*2878# WAIT 10 SECONDS PHONE WILL REBOOT NOW ENTER #745625*638*00000000# PHONE SHOULD BE UNLOCKED NOW TRY YOU SIM AND SOMEONE ELSES YOU CAN USE DIFFERENT NETWORKS NOW GOOD LOCK.
SOURCE: i need to hard reset my phone
I hate to say it but you are very wrong mr samsung expert. One simple code will hard reset just about any samsung phone so remove your sim card from your phone and type
*2767*3855#
Now your phone will reboot and viola all codes, phone numbers, pictures, everything has been erased.
SOURCE: pair motorola H500 to samsung eternity SGH-A867
I have had this problem too. Here is what worked for me.
1) With the Motorola H500 OFF, press and hold the talk key until you see a steady, non-blinking blue light.
2) Keeping that button pressed, turn on the bluetooth on the samsung eternity.
3) It should now find the H500, click on it and select connect.
4) Put in a pass key (I just put in 0000) and your done.
SOURCE: how to reset my Samsung Eternity SGH-A867
Master-Reset: all personal data will be deleted *2767*3855#
