SOURCE: HTC II, Blackberry software driver
Here is the solution for the BBC.
Install instructions from forums:
1) goto hklm>system>versions and change what ever is there to .0.4.2 (The leading . before the 0 needs to be there)
2) Install bbconnect cab file.
3) If you don't get the check boxes at the end of the install (Calendar, notes, etc). Re-run the install (it will remove the 1st instance), I always get it the second time.
4) Wait for Blackberry to finish "setting up device for first use" and let it reboot.
5) On reboot, status will now show the PIN number.
6) Open the Blackberry connect desktop application. (Make sure you have access to your corporate e-mail) If you do you will see "Configure Wireless Device" as active.
7) Plug in the Tilt and wait for Activsync to finish syncing and says "connected".
8) In the BB Connect desktop application hit the "Configure Wireless"
9) When finished unplug Tilt and soft reset.
10) You should be good to go at this point.
- Get BBconnect cab file from: http://www.america.htc.com/mobile/connect/8925/
- Make sure your remove all ActiveSync synchrnonization in Comm Manager -> Active Sync-> Options for your PIM.
- Install cab and run blackberry app
- Go in PIM tab and selct all PIM items you want to sync with
SOURCE: How can i download Skype for my HTC TyTN II?
Download it to your PC and install from there using a USB cable.
http://www.skype.com/download/skype/windowsmobile/
SOURCE: EDGE/GPRS not working in HTC TyTN II with Windows Mobile 6.1
i know this is old, but i recently bought an acer phone and my gprs internet stoped working as well, the 'E' (i think it stands for edge) changed to 'G' and the gprs internet stopped working, its a postpaid connection.
SOURCE: how to format SD memory card in HTC TYTN II smartphone
Simply go to your settings, tape on sytem, then click on clear storage wala you have formated your HTC Tytn 2...
