Question about Saniflo Plumbing
The undersink macerator has just started to draw in and pump from the top feed pipe every few seconds. The pump was getting hot so have turned it off and left t overnight. Turned on again this am but still trying to draw water/waste from top pipe which sits on lid. Have turned off pump.
The "tank level" switch is stuck on. You may be able to clear it by cleaning the system/pump with a water hose (outside of course) so you will have to take the system apart then give it a good cleaning. May not help but at least you will have tried.
Posted on Oct 07, 2012
Testimonial: "Problem resolved prior to this posting but the solution is very helpful and gves me more info for the future."
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
SOURCE: I recently had a Saniflo unit replaced after 20
David,
I am not directly familiar with this unit but have worked with others. The bubbling sound at the end of the run does sound odd. My thoughts go towards venting of this discharge pipe; is this properly vented?
Thank you,
Tom
Posted on Sep 25, 2009
SOURCE: How do you take the lid of a Saniflo macerator?
its blocked dont put paper or towles in it sorry to say its amessy job discont fromtoilet inlet have a bucket and mop handy
Posted on Nov 14, 2009
SOURCE: saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
Posted on Jan 31, 2010
SOURCE: The Pump overheated
IS IT'S A STA RITE CHANCES ARE THE PUMP CAN BE SAVED. IT WILL NEED A NEW IMPELLER,SHAFT SEAL AND DIFFUSER. THESE ARE TUFF PUMPS. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY .. USE YOUR ZIP-CODE IN YOUR SEARCH ..PUMP REPAIR IS THE GREEN THING TO DO AND IT SAVES YOU MONEY ! . PLEASE VOTE GUYS-N-GALS
Posted on May 22, 2010
Jul 20, 2015 | Saniflo SANIPRO Macerating Pump
Jul 10, 2015 | Saniflo Plumbing
Nov 28, 2014 | Saniflo & Saniplus& Macerator Pump
Jan 30, 2013 | Saniflo & Saniplus& Macerator Pump
Nov 20, 2012 | Saniflo & Saniplus& Macerator Pump
Jun 20, 2011 | Saniflo 002/003/005 Saniplus Toilet with...
Oct 27, 2009 | Saniflo & Saniplus& Macerator Pump
Aug 03, 2009 | Saniflo & Saniplus& Macerator Pump
Jul 05, 2009 | Saniflo Sanibest macerator with multiple...
Aug 09, 2017 | saniflo"" turboflush toilet"
288 people viewed this question
