Error Code 03 Power comes on then code 03 displays belt don't start.
SOURCE: canon ir 8500 error code 001-010 and E 001-003
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
SOURCE: Error code "L" & "1"
L1 indicates a scanner feed problem. Make sure the scanner isn't locked in the shipping position. It is underneath the scanner where the paper exits the machine. Look for a plastic dial and turn it one way or the other.
SOURCE: I have four Treadmills of
I will start from your Question 2 than Question 1 :)
Now,
Error 211 - Clear the error by pressing Power or Clear. Attempt to operate the treadmill again. If error persists, replace VSD or grade motor. Belt and display may continue to be used during Fault conditions by pressing Clear.
Error EPLO - It refers to an electrical problem or might be a Blown Fuse.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Testimonial: "I got good confidence with your help, It is exceptional good service, I would sujest please use some words instead of writing in code words like "VSD""
SOURCE: display reads E-7 03
E7/03 is a lsu error. The LSU is the “printer head” of the printer. But instead of emitting ink, the LSU emits a laser beam, directing it at the drum of the toner cartridge. If replacing the lsu does not fix it it may be the mcu pwb, but most likely the LSU.
SOURCE: error code on display, L1 or 1L flashing. What is
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
