Cannot figure out how to make it pick up the photo paper!!! which direction is the photo paper is supposed to lay!
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
SOURCE: Cassette error
On the control panel for the printer, there's a Feed Switch button that's easily touched by accident. Ensure the Feed Switch is set to the paper source you're using (e.g. either the back or front). The graphic of the printer next to the Feed Switch button will light up to indicate the paper tray it's attempting to use.
SOURCE: Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
SOURCE: canon mx700 printer
Using a q-tip clean the rollers with rubbing alcohol.
Try different paper. The fact that it grabs more than one page means the paper or rollers are dirty.
SOURCE: Canon ImageClass MF6550 Won't Pick up Paper or Feed Thur in Multipurpose Tray
Clean the pick up roller
