Question about Vivitar 283 Flash
Vivitar 283 on a digitial camera?
I have a Vivitar 283 Flash for my Pentax 35mm Camera and was wondering if i could use this on my Nikon D3100. It fits on top and locks but Before i turn it on or anything I would like to know if it can be used with my digital camera or will it do something to my digital
Posted by p_m_photogra on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
It depends on the variant of the 283. Take a look here.
Posted on Aug 27, 2012
4 Related Answers
Anonymous
  • 216 Answers
SOURCE: Vivitar 283 flash
Please check the trigger voltage.
What, how do I do that, you said!!!!!!!!!?
Here they are:
1. Four fully charged or new batteries into 283.
2. You needs a DVM (Digital Volt Multimeter).
3. Set DVM: DC scale, higher than 10 scale.
4. Black Lead to black DVM and Red Lead to red DVM.
5. Turn ON the Vivitar 283 and wait until light turns Green.
6. Place Black Lead to Outside Silver Contact of the flash.
7. Place Red Lead to Center Silver Contact of the flash.
8. What is the voltage reading? Read the max. V.
9. Anything under 8VDC will be fine.
10. Some versions will be high.
Hope they are helpful to all photographers.
Truly,
Alexander
[email protected]
Posted on Dec 13, 2007
Anonymous
  • 103 Answers
SOURCE: Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Posted on Dec 21, 2008
Anonymous
SOURCE: Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Posted on Feb 22, 2009
bhargav
  • 66 Answers
SOURCE: Can the Vivitar 283 be used safely on Nikon
Vivitar 283 is not safe to use on digital cameras
http://www.acecam.com/photography/2108.html
Vivitar 285 HV is safe to use on digital cameras
You can buy wireless flash trigger from ebay for 18$ to use ANY flash wto use with any digital camera.
Posted on Mar 04, 2010
I am looking to purchase a Vivitar 850AF. I have two cameras, a Nikon D40 and a Nikon D3100. Is this flash compatible?
yes to both. You just need the nikon shoe
Search Results
Vivitar 850AF Electronic Flash for Nikon Cameras: Amazon.ca ...
https://www.amazon.ca/Vivitar-850AF-Electronic-Flash-Cameras/dp/B00007E8EW Vivitar 850AF Electronic Flash for Nikon Cameras: Amazon.ca: Camera & Photo.
Vivitar 850AF Electronic Flash for Minolta Cameras: Amazon.ca ...
https://www.amazon.ca/Vivitar-850AF-Electronic-Minolta-Cameras/.../B00007E8EV This is a perfect flash for a mid-level or advanced beginner photographer. Instruction manual verifies its specific compatibility with Canon, Nikon, and Minolta. I highly recommend it to anyone wishing to supplement their camera's built in flash. It is a hot shoe flash and will sync with any of the three brands. It has both auto and ...
Amazon.com : Vivitar 850AF Electronic Flash for Nikon Cameras : On ...
https://www.amazon.com/Vivitar-850AF-Electronic-Flash-Cameras/.../B00007E8EW Buy Used and Save: Buy a Used "Vivitar 850AF Electronic Flash for Nikon Cameras" and save 90% off the $249.95 list price. Buy with confidence as the condition of this item and its timely delivery are guaranteed under the "Amazon A-to-z Guarantee". See all Used offers.
Vivitar 850AF Shoe Mount Flash for Nikon ('for Nikon') ' eBay
https://www.ebay.com > Cameras & Photo > Flashes & Flash Accessories > Flashes
Capture clearly illuminated pictures even, in the dark, using the Vivitar 850AF TTL shoe mount flash with your camera. With a guide number of 120, this Vivitar camera flash for Nikon ensures that even a distant subject is adequately illuminated. With a 28 mm 85 mm zoom range, you can widen or narrow the field of ...
Mar 06, 2018 | Nikon Cameras
I have a nikon d3200/vivitar 283/wein voltage adaptor/good sync cords and still no flashoutput,help rick
just to exclude anything faulty, start with the flash on the camera and check if it works. Also check the camera settings. On your Nikon you can chose flash off. Don't do that. If you get the flash working on the camera then you starts with the extension cord and it still should flash in the same conditions.
May 06, 2014 | Vivitar 283 Flash
Vivitar 283 not firing on Nikon FM
Did you get the cord with the flash unit, If so then try that to see if it's the camera, Cords are cheap to buy if you didn't rec it,
Sep 21, 2017 | Vivitar 283 Flash
I have vivitar 2800 flash for my pentax can i use it with Nikon D70s
If there is a D after the 2800 you're probably safe. The trigger voltage is 8 volts so to be sure, find out what the upper limit of trigger voltage the camera can safely handle. If there is no D designation in the model number it will definitely fry the Nikon
Mar 14, 2013 | Vivitar 283 Flash
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
Is it compatible to use with a Nikon D-50?
No, the Vivitar 283 does not have TTL (Through The Lens metering capability) and the voltage in the flash may be much higher than that in the camera. Some of the old 283 flashes had a very high operating current that, when the flash is left one and removed from the camera can damage the camera operating circuts. Find a Nikon SB 400, 600, 800 or 900 speedlite, or a Promaster 7200 or 7500 for a great less expensive flash for this camera.
Nov 20, 2009 | Vivitar 283 Flash
Jan 06, 2009 | Vivitar 283 Flash
Vivitar 283 flash will not work on camera.
To test everything except the camera, just short the contacts on the Wein protector. If the flash fires, the problem is in your camera, and maybe the protector did not do its job as good as expected.
Good luck
Aug 29, 2007 | Cameras
Vivitar 283 Flash Logo
266 people viewed this question
Top Vivitar Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Barbat Nae
Barbat Nae
Lee Hodgson
Lee Hodgson
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
