Question about Sony KP-57HW40 57" Rear Projection Television
Sound I get sound but not on all tracks
Posted by Ray Rios on
SD Tech
    Top Expert:
  • Sony Master
  • 14,553 Answers
The set which is older has sound or not----? model listed here is stereo.
Posted on Aug 27, 2012
I am using Adobe audition 1.5 for recording my songs.. now.. i am facing big problem while using that software.. there is multitrack option available in that software. we have put karaoke track in one...
Welcome to FixYa!
I assume that you know your way around adobe audition 1.5 because I'm currently using adobe audition 3 on windows 7. The menus are different, but I'm going to give a few points that might help.
Windows Sound/Volume:
Make sure that the sound card you are using is selected, specially if you are using an additional external USB sound card (which is much better). Disable other sound cards, if any.
Adobe Audition:
One of the pull down menus located on the upper part, it has an option that says "Device Properties" or anything like that. This is where you set the input signal will be coming from and likewise the output signal.
The input signal should be the input of the sound card you selected in windows. Same goes for the output signal.
On multi-track view, check the track to be recorded. Make sure that the input is from the input of the sound card and not from anything else. The button for the setting is somewhere near the Solo/Mute/Record buttons.
If this will be set correctly, you will be able to play the song on the 1st track and record ONLY your voice on the 2nd track.
Keep me posted.
Thanks for using FixYa.
Jas247
Apr 09, 2011 | Adobe Audition 1.5
I have a standard DP 02 (non cf) and I want to add vocal tracks to a previously recorded song (tracks 1 and 2) and I don't get any sound from my mic. The mic/line/guitar switch is set to mic/line but the...
you have to make sure the song tracks(1 &2 ) are not armed. then you can assign your vocal to any of the other tracks. after you do this , make sure you arm the track. you should be able to hear your mike.
Apr 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
When bounce tracks on my micro-br there seems static going on
First of all, it would be better for you to pan the tracks, and bounce into 2 tracks for stereo separation.
Your "static" may stem from three pausible causes.
One, four tracks into mono may make your output a little muddy.
Two, watch the reverb - if you keep applying reverb after each bounce, it starts to sound bad.
Three, if you have drums/rhythm, turn it off while bouncing. Only have drums on when mastering, because they will keep getting re-recorded during bouncing.
Go to bossbr.net - The best place to get answers!!!!
Sep 27, 2009 | Boss Micro BR Digital Recorder
Recording guitar tracks on my computer are out of sync help
Most recording programs have a some way to keep tracks in sync. It is usually some type of begining and end marker. When you press record for the second track it starts the begining marker. What is the program your using?
Mar 14, 2009 | Dell Dimension 2400 PC Desktop
Only plays one track from from DVD sound
Plug in center speaker -- seems right and left speakers are secondary carrying only the background / sound affects.
Jan 10, 2009 | Televison & Video
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
Tracking
A CONSTANT streak anywhere on the screen could be a scratch in the tape itself. Losing sound, and ocassionally everything going to black and white, sounds like a dirty control track head.(The audio and control track are in the SAME head (a 3/4" metal cube that the videotape travels on). The control track section is on the upper part, and the audio on on the lower part.
If the control track head's dirty I'm sure the rotary head's dirty too! Losing audio and have tracking problems, point to dirt. And you MAY have SO much dirt built up on that head it's scatching your tapes (unrepairable), and causing you problems. Make sense?
Mar 16, 2008 | Sylvania 6260VF VCR
Sony KP-57HW40 57" Rear Projection Television Logo
27 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
