Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
Lily Cheng Posted on Nov 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just installed new Chamberlain motor but makes loud snap when door opens and closes about 3 inches from ground?
I just installed a new motor unit only - the belt and trolley are from the original set. When I tested the unit, it makes a loud snapping sound when the door first opens and the motor unit moves so it must be catching on something? It then opens ok, but makes that same loud noise when the door closes to about 3 inches from the ground.
Don Eagan
Level 3:
Master:
  • Chamberlain Master 714 Answers
  • Posted on Nov 08, 2017
 Don Eagan
Chamberlain Master
Level 3:
Master:
Answers
714
Questions
5
Helped
272010
Points
4898
Do you have a security system in your home? Sometimes the door shut sensors get out of alignment and the door strikes the sensor. This is the exact same problem I had with my door.
5 Related Answers
Anonymous
  • Posted on Dec 17, 2009
SOURCE: Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
swolfinor
STEVE WOLFINBARGER
  • 504 Answers
  • Posted on May 27, 2010
SOURCE: door would not close all the way
DOES IT REVERSE OR STOPS BUT NOT TOUCHING THE FLOOR?
IF IT DOESN'T TOUCH THE FLOOR YOU EITHER NEED TO ADJUST THE DOWN TRAVEL OR LENGTHEN THE CONNECTING ARM.
IF IT REVERSES YOU NEED TO DETERMINE IF IT IS THE SENSITIVITY OR THE SAFETY EYES.
Anonymous
  • 143 Answers
  • Posted on Sep 03, 2010
SOURCE: chamberlain silent 3/4 hp red led on side and hear
This beeping is actually the battery back up unit making this sound. It either means there is no power to the outlet and it is using stand by power or that something is wrong and the battery is not charging correctly or will not take a charge. You can order replacement parts at chamberlain.com. Thanks BB
Anonymous
  • 143 Answers
  • Posted on Oct 11, 2010
SOURCE: The belt on my Chamberlain Whisper Drive dipping
Where the belt attaches to the trolley carriage which attaches to the door there is a black adjustment nut with a spring on it. Tighten it up more by turning it clockwise until the belt tightens up. The belt will droop a little when the door is all the way shut normally but should not during operation. If you tighten it up too much the belt will slap on the rail during operation. Make sure the spring is set on the adjustment screw too. This holds the belt tight over time. Thanks BB
Anonymous
  • 143 Answers
SOURCE: Chamberlain hd900d garage door opener
You will have to open the unit and look inside it. Unplug it first. It should have 6-8 screws to take off. You will see 3 white plastic adjustment screws. There is a carriage they sit in. Make sure they are in this carriage. If you would like stay back a bit and plug it in and watch it run to see how it works. It is a direct contact system, so when the middle screw touches the copper limit of the limit screw it stops. Thanks BB
Garage door stuck in the down position then 2-3 inches off the ground
Check for broken door springs or remove the cover from the motor unit and check the drive gear. It is white nylon and will be obvious if it is bad.
The sensor lights are steady. The opener cycles fine withouit the garage door connected. Everything worked fine until yesterday. I hit the open remote and the garage door did not open. I hit close and it...
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. Also check the door springs. One of them could be broken.
My door closes fine, but when opening, it only
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped. If so you will also find what looks like white sawdust inside the motor unit.
6helpful
2answers
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
2helpful
Chamberlain 1265 garage door opener, tried to
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the same direction as the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Installed new PD432D opener from Home Depot. Inadvertently ran motor before connecting rail and screw drive. After connecting, I cannot get upper limit adjustment to bring rack all the way to full open...
You have to set the limit adjustments to the factory settings and then make sure the trolley placement is in the up position and install from there. You can't do this by simply adjusting the limits. This might be a case when you hire an installer. 100.00 dollars should do it, depending on the market. Thanks BB
Top Chamberlain Building Materials Experts
Jose Ramirez
ADMIN Andrew
ADMIN Andrew
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
