Question about Akai PDP42Z5TA 42 in. Plasma Television
My AKAI 47' powered off, smoked-smelled, was checked by repair, no problems. Heard 2 pops, unplugged-HELP!
Posted by Alecia Anderson on
  • Alecia Anderson Aug 29, 2012
    Very helpful, I have an appointment with Best buy in home.
SD Tech
    Top Expert:
  • Akai Master
  • 14,553 Answers
Where there is smoke, pops something went---find another shop that knows what they are doing---never plug in a set that smoked!
Posted on Aug 27, 2012
1 Related Answer
Anonymous
  • 6 Answers
SOURCE: No Picture or Sound
IF YOU LIVE IN THE UK YOU CAN BY A REAPIR KIT FOR IT , IT COSTS ABOUT £12 FRON CHS POCKLINGTON
Posted on Feb 15, 2008
MY 1993 CLUB CAR GOLF CART WILL NOT MOVE, I HEARD A LOUD POP WHEN I WENT FROM FORWARD TO REVERSE/ANY SUGGESTIONS?
check to see if there is a circuit breaker on the wire path from your batteries. Could have blown the motor but You would see some smoke more than likely, and smell it burning. What you described with the popping sounds like an electrical short where the wires just burned up but again you'd smell it and maybe see smoke. The switch may be bad also check it with a meter to see it its making contact and see if voltage is coming up to and exiting the switch.
Aug 06, 2013 | Dual Club Car Lester Power Drive Charger...
Tried to start the engine and before it started, i heard a pop and felt the gas pedal come back to my foot. opened hood and the plastic engine cover was in pieces, anyone ever heard of this. it has
Why are you telling us or asking whatever your asking,
when it sounds like you know what happened & what
the possible damage is
Have to look it over or have repair shop do so, if your
not into car repairs,& resolve all issues
Jan 18, 2013 | 2003 Ford Escape
Heard a pop and then red light flashed 6 times then repeats. Installed new light bulb, already replaced housing door from previous problem. When starting back up, lamp indicator flashes.
Okay sounds like a power supply problem. The "Pop" was probably a Blown Capacitor. Did you smell smoke or see smoke? I would check the power supply. If your not familiar with changing Capacitors. leave it to a pro. If you decide to tinker with it . Make sure its unpluged and Electrolitic Capacitors. are drained. Look at the Capacitors they will look like tiny soda pop cans. The good caps will have a flat top the bad caps will have a protruding bulge on the top. and probably have a yellow leakage on top. Don't mistake factory glue for cap ooze. factory uses glue to hold components so to solder them.
Hope this helps.
Be careful . I can't stress this enough. Unplug the thing first,.
Normally you would unsolder the cap and test it. Caps can blow out with no sign of bulge on top.
Dec 26, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have a Carver Magnetic Field Power Amplifier,I turned the power on and heard a pop and I thought I saw smoke?
Does your speakers correct connected? This amp Circuit, burned. Send for repair on Professional Audio Repair shop.
Nov 29, 2009 | Audio Players & Recorders
MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Jan 05, 2009 | LG RU-27FB30C TV
Vizio L32 HDTV - Blew Out, No Power
Yes, I do in home warranty work on vizeo, it sounds like you need a power board and perhaps a main board. The power board is what pooped.
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 13, 2008 | Vizio L32 32 in. LCD HDTV
AudioBahn A2300HCT no sound
Generally, if the amplifier smokes, the power supply FETs have failed.
Many times, the output transistors fail and that causes the power supply FETs to fail.
Audiobahn won't release schematics. The amplifiers are relatively simple and a schematic isn't generally required.
If you know how to check the transistors, check them to determine the severity of the damage. If you don't know how to check them, read through the following page following all links provided.
Basic Amplifier Repair
Let me know if you have any other questions.
Sep 04, 2008 | AudioBahn A2300HCT Car Audio Amplifier
No Picture or Sound
Dec 04, 2007 | Akai PDP-4216M 42 in. Plasma Television
Akai PDP42Z5TA 42 in. Plasma Television Logo
Top Akai Televison & Video Experts
Paul Bade
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
