Computers & Internet Logo
Posted on Aug 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have toshiba laptop but during using when i plug the charging pin, it got suddenly shut down
Sal Sandoval
Level 2:
Habit-Forming:
New Friend:
  • Expert 56 Answers
  • Posted on Aug 26, 2012
Sal Sandoval
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
56
Questions
21
Helped
9333
Points
152
Is your laptop working normal just with the battery? if it is remove the battery and try to power up the laptop with the power supply if shuts down have some one test the power supply for a short in it and the plug in part of the loptop.very posible there is a short in the line that connects the power supply.
5 Related Answers
Anonymous
  • 121 Answers
  • Posted on Dec 06, 2007
SOURCE: shut down suddenly
Do you get any error-beeps of any kind? Like the battery is going empty? Or does it just go off suddenly? If the first is the case, your power connector in the computer or perhaps the powersupply could be broken. It could sound like your battery doesn't get charged and your computer isn't getting power. Then it will shut down. See if the power/charge indicator is on when connected to the power grid.
If it blacks out suddenly it's probably a more severe problem, but you might try to reinstall the OS (I'm guessing windows), but only as a last resort.
frankzjm
Frank Zhang
  • 191 Answers
  • Posted on May 14, 2009
SOURCE: Amilo Pro v2065 shuts down when battery is plugged
you need do check:
1) no charging means adapter input problem, first check your adapter DC output voltage is ok
2) check DC jack socket on the motherboard:
--- DC socket any pin disconnected, you need use iron and flux to fix it
--- DC socket damage(broken),you have to change it
3) if DC socket connection normall, the DC/DC circiute near around DC socket some component damage, you need find a technacian to repair.
hope help you to deal it well
Anonymous
  • 674 Answers
  • Posted on Jun 04, 2009
SOURCE: laptop suddenly shut off and will not turn back on
that is hardware problem,, check the processor maybe this over heating only. the cfu fan not working very well just clean the cfu fan....thats all..if over heating problem, cause of ove heating, auto shut off the pc/ laptops.. even the battery full charge.. sometime then hdd comes bad sector cause of auto shut off.. be care full you must wait untill became cold you boar then open again.. thanks
CSLear
  • 15 Answers
  • Posted on Jun 18, 2009
SOURCE: sudden shut down
You probably have a clog of dust between the fan and the heatsink. It would be best to have it disassembled to clean, although a few models have clean-out doors to the fan on the back. You might be able to somewhat clear it by blowing canned air in the vent, but this may push dust balls into the fan that go right back against the heat sink.
Anonymous
  • Posted on Dec 05, 2009
SOURCE: My Toshiba Satellite A75-S211 computer, will suddenly shut down.
Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
2answers
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
1helpful
Computer shut off suddenly, will not turn back on
Is the laptop charging when you plug the charge on?
If not you need to let a technician look at your laptop.
2answers
Laptop suddenly shut off and will not turn back on
Sometimes the voltage regulator in the battery hit a point where they fall below a certain efficiancy % they have to operate at. Once they fall below that % you must replace them, even if the battery is 100% charged. Its usually a good idea to pick up a new charger as well with a new battery since they are known to die as well. Make sure you check the socket in the back where your charger plugs into the laptop to make sure its not loose or cracked. Sometimes the plug will crack off the motherboard and not make good enough contact.. But regardless of that it should atleast turn on if the battery was charged and good. Best bet, new battery. Every 2 years you should get a new one.
you need do check:
2answers
Toshiba Satellite A105 laptop keeps shutting off for no reason.
I think your fan might be broken....if the fan doesn't cool the pc,the processor or the chipset will automatically shut down the pc to prevent burning hardware.Or your hard drive might keep crashing.Oh yeah and abstract from this i don't recommend ever using mcaffe
DELL D520 LAPTOP
Problem cause:
Do diagnose your Laptop try to change your battery or adapter if you have some backup device
Shut down suddenly
Acer Travelmate 270 - battery problem?
IT sounds like your laptop or powersupply/charger is at fault. Try to use a different charger, and if possible use your battery in a different computer. That way you can narrow down where the problem is. It might ba a faulty connection where the charger is connected to your computer. To check this out, try running the computer on AC without the battery installed. If it suddenly shuts off it's a problem with your powersupply or possibly the connection plug in the cimputer.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
