Short beep, so no beep code problem indications. Will sometimes boot to Ubuntu. Cleaned all the dust bunnies and blew out the heat sink with canned air. This brought the CPU temp down by 20C. But problem still persists. Runs the BIOS with no problems. I have been watching the CPU temp in the BIOS for an hour or so - varies between about 35C to 37C. If I exit the BIOS and boot to UBUNTU, it lasts about a minute or two before shutting down. Sounds to me like CPU temp goes too high under load. Any other ideas? Thanks,
SOURCE: continuous short beeps on power up.Then shuts down
enter bios setup and check the temperature of your mobo and cpu if it's above normal and also check the cpu fan's speed if theres no problem with these three then try to remove all the expansion cards you have then reset the memory modules if the beeping continues try a different PSU and memory modules.
SOURCE: GA-MA790GP-DS4H doesn't boot. It gives 14 short
Hello my friend,
There is no way to have 15 beeps error especially short ones so
First try to count the beeps and if are long or short
SOURCE: Packard Bell IMedia 5055: GA-8SIML will not post
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
