Question about Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S Lens
I have a Nikon AF-S 55-200mm 1:4-56ED. Focuses fine, lens goes in and out fine...except...it doesn't retract completely flush with the barrel of the lens. Is this a big problem?
It appears that the lens will not completely retract into inside....and I am not sure how to get the camera to do this automatically. I have been used to another digital camera that had a telephoto/wide angle lens button. Any suggestions?
    Guru:
  • Nikon Expert
  • 362 Answers
I do not have that particular lens in my collection, but not all lenses do completely retract to a flush position. If your lens performs well at all focal lengths and takes sharp pictures, it is probably ok.
Posted on Jun 18, 2014
6ya staff
SOURCE:
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon 18-55mm lens will no longer zoom to 55mm.
there must be a problem with the lens ring which are fitted inside, occasionally it gets worn out because of improper handling . alignments may have caused you the problem. but once again you need a professional help because you wont get any elements or parts easily except from the company.this lens could also may have jammed due to any reasons, may be a foreign body or so and because the af is OK you are still getting a sharp image up to actual 45 mm which you think to be 55mm. If i were you then I would have inverted the lens and tapped gently and then check it once again or best goto Nikon service centers .
Feb 06, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My friends father recently stumbled upon a 100-300mm quantaray. It connects Nikon 3000 and my d5000 but the af doesn't work. We've looked it up and down for a button to switch to AF but there's...
That lens has a coupling on the lens mount which you'll see rotating when you alter the focus ring and look at the back of the lens. it does not have an in-built focus motor and so will only autofocus with Nikon bodies which incorporate a mechanical AF coupling on the lens mounting flage.
May 17, 2011 | Quantaray Cameras
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
Sep 28, 2010 | Nikon Coolpix S3000 Digital Camera
I have a Nikon d3000 and a Tamron AF 55-200mm lens. I cant get the lens to autofocus with my nikon
The Nikon D3000 does not have a focusing motor built-in, relying on the lens to have a motor. The Tamron AF 55-200mm does not have the necessary motor; it only auto-focuses with Nikon cameras that have the motor in the camera body.
For Nikon lenses, you need lenses designated AF-S. For Tamron, you need lenses designated USD and/or BIM.
That probably wasn't the answer you wanted to see, but there it is.
Aug 08, 2010 | Tamron 55-200mm f/4-5.6 Zoom Lens for...
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Good day, I have a Nikon D1X. The shutter button when slightly depressed should engage the AF in the lens. The lens is a Tamron. The camera Auto Focuses fine when you press either of the two AF buttons on...
You are correct, there is a setting. Press Monitor, then Menu to get to the menu; go to the thitd menu option (looks like a pencil), select option 4 (AF Activation) and set it to ON (Shutter/AF ON). This will solve your problem.
Dec 15, 2008 | Nikon D1X Digital Camera
Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S Lens Logo
91 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
