Oster  Fpstdh0101 4tray Electric Food Dehydrator Logo
Faline hughes Posted on Aug 26, 2012
I need a manual for oster food dehydrator
When I purchased this product there was no manual with it
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Aug 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
Helped
2574
Points
23
Go to the yahoo search bar and type in manual for oster food dehydrator if you have a make and model on it it will make the search more accurate ..in most cases you can find an online manual in a PDF file format...hope this helps.
2 Related Answers
Anonymous
  • Posted on May 11, 2011
SOURCE: i need oster food dehydrator
i can scan mine and email you a copy if you want
Anonymous
SOURCE: How can I download a
i could scan mine and email you a copy
Need house & home dehydrator manual
Hello, Vickie -
Do you know the model of your House & Home Food Dehydrator?
Apparently the House & Home Model LD-1010 Food Dehydrator is the same as the Magic Chef Model LD-1010 Food Dehydrator. Also, I have seen information indicating the model LD-1010 is the same as (or very close to) model 469-1. Perhaps yours is a a model LD-1010
I have not yet found a PDF version (electronic, Adobe Acrobat Reader software) of an instruction manual for a House & Home food dehydrator or a Magic Chef food dehydrator, any model.
However, I have found directions (not the full manual) for using a Magic Chef food dehydrator here:
https://www.leaf.tv/articles/instructions-on-using-a-magic-chef-food-dehydrator/
I have found manuals for other similar food dehydrators (PDF documents), which may prove instructive:
http://pdf.lowes.com/operatingguides/1000317095_oper.pdf
and:
https://www.manualslib.com/manual/107232/Mr-Coffee-Fd5.html
Note: I also found a 1997 U.S. Consumer Product Safety Commission for a K-Tel Model LD-1010 food dehydrator:
https://www.cpsc.gov/Recalls/1997/cpsc-k-tel-international-usa-inc-announce-recall-to-replace-food-dehydrators
I have not been able to determine if the K-Tel product was manufactured by the same company which made the House & Home LD-1010 Food Dehydrator or the Magic Chef Model LD-1010 Food Dehydrator. However, I recommend you read the full recall notice and be watchful for any overheating when you use the dehydrator.
Note: If you eventually choose to dispose of the dehydrator, please do not toss it in the trash. Instead, make sure you send it to electronics recycling in your area.
Best wishes.
2answers
Oster Fpstdh0101 4tray Electric Food Dehydrator wattage
well, I'm guessing on the tag or label it shows something like this
120V ~ 60 hz 10.5 amps or
120V ~ 60 hz 10.5A or
120V ~ 60hz 11A (some manufactures round up if it falls into the same wire gauge)
120Volts ~ 60hz 1260w or
120Volts ~ 60HZ 1260 watt
120V stands for normal operating voltage
"~" means ac current
60 herzts stands for how many cycles
So if your unit shows only amps, it's really simple to figure out wattage
take the voltage shown, in my example it's 120, then multiply the amps, in my example it's 10.5. So 120 X 10.5 = 1260 watts
W = V * A
and vice versus, if it only show wattage and you needed to know what gauge wire you needed to run a receptical to operate it
AMPERAGE = VOLTS / WATTAGE
10 tray dehydrator - Airite need an instruction manual
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
1helpful
2answers
Hi I purchased a Nesco food dehydrator at a yard sale and need a manual for it . Model fd60, can I print one off the internet for this model?
I would think that any dehydrator information would work for you.
You just have to be sure the components are working (ie. fan and heating coil.) A dehydrator is pretty basic.
http://www.food-dehydrator.com/food-dehydrator/books.aspx here is a link for books on a site that sells the product.
You can find a lot of books at the library too.
This might also help, dont let the name fool you: http://www.astray.com/recipes/?show=Dehydrator%20general%20instructions
With some searching on line you will be able to find a lot of instructions and probably even ones for your specific dehydrator.
Look on forms about drying foods and ask for the basic instructions if you find you really need them after looking at the links above.
There might be someone willing to scan them and email them to you.
Top Oster Kitchen Appliances - Others Experts
John
John
Sean Wright
Sean Wright
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
