Question about Panasonic PT-51HX42 51" Rear Projection Television
Dark picutre on panasonic
Picture dark with brightness all the way up
Posted by deborah schneider on
SD Tech
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Clean the three lens inside and or the mirror if dirty---be careful.
Posted on Aug 27, 2012
  • SD Tech
    SD Tech Aug 27, 2012
3 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: My Panasonic HDTV Projection Monitor/TV
THe coolant in the CRTs most likely needs to be replaced. this is a very common problem in Phillips and magnavox rear projection TVs.
Posted on Sep 11, 2008
Anonymous
  • 8 Answers
SOURCE: my picture is dark and have changed the brightness
This model is notorious for needing a new lamp about every 2 years. The lamp is accessed through the front by removing the long plastic cover under the screen (it just pulls off). Under that, to the left of center, is a square cover with one grey plastic screw. Loosen the screw and pull the lamp assembly out. It should just slide right out. Turn it around and look at the lamp. If the lamp face or reflector looks "cloudy" or "misty". Replace the lamp with Philips part number TY-LA1000. Just Google the number and you will find them available for around $100
Posted on Mar 18, 2009
Anonymous
  • 261 Answers
Hello!
Well it seems that your lamp is about to go out, replacing the lamp might jus do it ! Also make sure you get a Philips lamps, they work like a charm.
And regarding the long plastic cover just be a little bity patient and you'll make it come off, just make sure you do remove all the screws.
Posted on Jun 30, 2009
Dark picture
Please check your TV's Picture mode setting. Use the VIVID picture mode to achieve the brightness video.
Mar 11, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Even with a new panasonic bulb;the picture is not as bright as when it was new.prob?
We replaced the lamp on our pr61lcx65 rear projector panasonic tv. We still have colorful spots and now it is getting darker and have yellow on bright picture and red on dark picture running through it. Please help.
Feb 10, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Chage bulb tv is still dark
The wrong or faulty lamp may cause darkness
Apr 21, 2009 | Panasonic PT-52LCX66 Projection Television
My picture is dark and have changed the brightness
Hello!
Apr 18, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Dark picture
@ 6 years old I'd be willing to bet that it's time to replace the lamp. They lose brightness over time so that could be what the problem is.
Dec 14, 2007 | Panasonic PT-47WX49 47" Rear Projection...
I need help bad
i'd say the picutre failed becuz it was too dark, and u didnt have your phone on night time for picutres, idk y it won't turn on though
Mar 16, 2007 | Motorola Mobility RAZR V3
Panasonic ctp2780sf Picture very dark
check the ABL at the flyback and solder any bad connections there. U can increase the brightness at the flybacks buttom control .
Dec 29, 2006 | Panasonic CT-27SF25 27" TV
PICTURE DARK
I had the same problem soI decided to go ask at our local tv shop Panasonic warranty place and he was nice enough to tell me the problem . So for everyone reading .. these had a defect with some of the disc capacitors they used on the CRT board it as 2 on there . The second problem is with the ``YC`` chip . panasonic sets have many unusuall malfunctions caused by this chip such as a black & white picture or brightness problems . unfortunatly my set has a bad chip . There we all learned something today . he invites you to contact a Panasonic ``rep`` he will tell you the same thing .
Nov 15, 2005 | Panasonic PT-51G44 51" Rear Projection...
Panasonic PT-51HX42 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
