Question about Sony CDX-M630 CD Player
Err 50 on sony cd radio how to get functions to work
Posted by kerry kozitzki on
1helpful
CD changer stopped playing, says ERR
The laser mechanism of unit has died and gone to laser heaven. You replace and do not repair. Simply not cost effective.
My radio in my 1993 geo prizm is reading error 9 what do I do
ERR message on GM Delco CD Radio after ejecting CD Now CD will not work
read that thread i linked
it's possible to reset that GM radio by removing the fuse waiting a while for it to reset then re-installing the radio fuse
otherwise, it's time for an aftermarket head unit if that err 9 returns
2helpful
CD Player Error ERR
The err is short for error.If the cd player accepts a cd and can't read it can cause err to display. The cd also can be scratched or the lens may be dirty or damaged.If you buy a cleaner cd and it doesn't work then its time to replace the radio preferrably an aftermarket because the factory type can cost up to $500 or more.
3helpful
Cd player reads err on display
internal problem in radio,you would have to take it to a dealer to send out for you,
1helpful
Cd stack in cd player,screen shows err
My CD Player did the same. It showed an "ERR" message when trying to detect the beginning of a CD. I thought that the CD was dirty and wiped it down. Then I discovered that the player would detect the CD when the car was idle, but not when the car was in motion. Maybe the laser is THAT sensitive. Hope this works for you.
2helpful
The CD Changer will not work and shows ERR 1 and I
The cd changer internal mechanism is faulty, replace the cd changer itself.
CD ERR 1
Have a 2005 Freelander and the battery died. When I re-charged the battery, the CD changer had a CD ERR 1 message. Could not eject or load a CD and the radio worked. I turned off the radio and pulled off the cover on top of the CD changer. I removed the two screws that hold the frame around the CD changer. I turned the CD back on and the CD went through a test on each CD. I know this solution might not work for everyone, but it worked for me
Err code displays when i put a cd into my radio.
the cd player only is the problem even though it is all in one unit the radio will still play. tr a different disk if no luck then unfortunatley the problem is in the radio itself. you can buy a nice after market radio for alot less money. keep me posted thanks
Replaced radio with one from same model year. Displays Err 01.
this generally means the laser is either dirty or the cd player is shot, err 01 is a disc reading problem. Try cleaning lens with cleaning disc first if this does not help i would replace the unit with another. i would recommend replacing it with a cheap aftermarket stereo.
2helpful
2answers
Cd player comes up with err message
Oh, i had this problem several times... look, the best answer that i can give you is to buy a new one, there's sony's cd-players that are great, me and my father have. now, if you want to stay with this cd player just insert the cd several times until it will play. but again, you better buy a different one.
Sony CDX-M630 CD Player Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
