Question about Orange Rio Pink Mobile Phone Unlocked
Restoring factory setting on an unlocked orange rio phone
Password to restore factory setting to rio orange phone,that is now unlocked to any network
Posted by tulisa aimon on
Keisha Halpin
    New Friend:
Need help
Posted on Nov 18, 2014
Computer Repairing
  • Orange Master
  • 14,641 Answers
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Aug 26, 2012
  • 5 more comments
  • Monica Barrett Apr 18, 2013
    Hi could you plz help me if possible? I can't remember the password to restore my rio on orange network, i have tried the suggestions you have given but with no luck :( the IMEI number is 352945042443440
  • richard Edanon Apr 25, 2013
    my IMEI Number is 352945042959361
  • BRAD THOMAS Apr 30, 2013
    hello could you help me please i dont know my password my IMEI:352945044377216
  • Anne Horwood May 10, 2013
    can you help me please ...my IMEI ; number is 352945041179524 , do not no my NP CODE
  • Baily Bedding Jun 12, 2013
    Please help, IMIE is 352945043972116
  • Peter Holland Jul 20, 2013
    Hi my IMIE no is 356352040597176 can you help
  • arni_bags
    arni_bags Oct 18, 2013
    please help my IMIE no is 353735048016483 please hepl me
2answers
How to unlock mobile password model i550 vgo tel?
Restore factory settings resat password
Aug 31, 2018 • Cell Phones
Factory restoring
3answers
2helpful
2answers
I forgot the celkon c9 phone restore factory settings password
If you need the reset code please, contact your service provider to get a master reset code at free of cost.
You can also visit http://www.unlock-zone.com/ and can see different options there to get unlock code for a price. Choose any price appropriate for you.
Regards
Jun 27, 2011 • Cell Phones
I forget my factory restore password.how can i get it
To factory Restore the Mobile...You need to Unlock it....You can get the Network Unlock code at here
http://www.wickedunlock.com/nokia-7610-supernova/rs11wp9/ and Unlock it...
42helpful
6answers
I can't put my nokia 6300 into restore factory settings mode..
The defaulkt security code for Nokia is 12345. You can reset the security code using : *#7328748263373738#. It works on most nokia phones. Worth giving a try.
And if the phone says simcard rejected, then the most common problem is that the phone probably might have been locked. You can get it unlocked for 5 quids in your local market.
1helpful
3answers
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
15helpful
3answers
How to Restore Factory Settings N99i
Shortcuts for phone settings
Change languge: *#0044# + dial for English
Check Version: *#8375#
Firmware verion: *#8882#
Test*#87#
Debug*#8899# (?)
IMEI number:*#06#
Restore factory setting:*#66*#
Factory settings:*#3646633#
auto test:*#87#
Password for restore factory settings: 1122
2answers
Unlock MMC
IF THERE IS NO PASSWORD SET IN THE SYSTEM. THE NOKIA NORMALLY DEFAULTS TO 1-2-3-4. TRY THAT, IF THAT DOESN'T WORK, TRY GOING TO MENU, THEN FIND SETTINGS, THEN SELECT "RESTORE FACTORY SETTINGS", AND IT SHOULD RESTORE THE ORIGNIAL FACTORY SETTINGS WITHOUT LOSING YOUR CONTACTS. GOOD LUCK............... JLR4
25helpful
4answers
How to restore nokia n70
cant send sms's. the smssync is no longer on my phone. need to restore the factory default software or get the sms sync to install on my phone. please help.
Orange Rio Pink Mobile Phone Unlocked Logo
Top Orange Cell Phones Experts
Ekse
Manoj
matt
matt
Are you an Orange Cell Phone Expert? Answer questions, earn points and help others
