Canon imageRUNNER 400S Copier Logo
Posted on Aug 25, 2012
Problem is canon ir 400 close the front cover?
Canon ir 400
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 15, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
997
Points
Sir namaskar, mere copier me one side light a raha hai...
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 06, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
958
Points
Its because of composit power supply(hvps) replace it...........
3 Related Answers
Anonymous
  • 64 Answers
  • Posted on Sep 09, 2011
SOURCE: canon ir 400 error codes
iF YOU HAVE CHECKED DOOR SWITCH AND IF IT IS WORKING O.K.
THEN THE PROBLEME LIES IN COMPOSITE POWER SUPPLY BOARD.GET IT REPAIRED.
Anonymous
  • 118 Answers
  • Posted on Jul 06, 2009
SOURCE: i have a canon ir 400 the machine shows close the
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Anonymous
  • Posted on Jan 11, 2010
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
I have a problem with my copier CANON IR 2016J error: close front or left cover, i tried to close them and did all i can still
if you've closed all covers and the error still exists, please restart the copier. If errors are still coming up, please check that all debris have be removed from your printer or any potential sensors . You can also clean the copier surface with material recommended by the manufacturer before restarting the device.
Thank you.
I have ir 400 machine its front door is close but error is close the front door whats problem
Either you misunderstand this message or the switch which says the door is closed is not doing so.
Ir 400 error 805 002
Your connector is not good is connected to the DC control board. That connector is J112, which is located in top 3 of left to write.
2helpful
3answers
How to fix canon ir 405 error cod E805?
it is related to FAN, check all the connection of fan.
11helpful
2answers
ImageRUNNER 400S Copier: Canon IR 330-400 Ps Ver 1.0 i keep getting the ...
E-100 is an error of the Laser Beam detect PCB. Either the laser unit is not working or the beam detect PCB is not detecting the beam. You can't see the beam so don't try. Since you are also getting a E-220 which is a Scan Lamp error. Most likely cause is a ribbon cable between the CCD unit and Image Processor PCB. You may need a tech to trouble shoot this problem
1helpful
2answers
I have Canon IR 400 photocopier. My problem is -
This not really a problem. Canon Copiers have various counters that track the counts of Various sized papers. Long, short and the like. The only counter that really matters in the 101 or total counter. This the counter that tracks every piece of paper that goes through the copier. This is the counter used to track copy usage. If you have a service contract this the counter the dealership will use to track copies for billing. Ignore anything but the total counter.
1helpful
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Canon IR210s copier
Are you sure you have the right toner??? It says it is for the IR-200-210 or dose it say IR-330 & IR- 400? If you look on the inside front door cover there are pictures showing how to install the toner, also there are pictures on the box the toner came in and also the display sceen will walk you through on how to replace the toner.. It slips in only one way and push down on it till it locks in then pull the blue tab till it displays "STOP" then push it back in and the push on the black part on the front of the developer unit to release the toner bottle and close the copier back up and lok the blue lever to the left and you are done. Good Luck
old marine
old marine
ZJ Limited
ZJ Limited
