Sony VAIO Digital Studio PCV-RX670 PC Desktop Logo
rhonda rawlings Posted on Aug 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony vaio pcv-rx671 power button light flashes (once) but wont turn on, and wont even flash again unless i unplug and plug back in?
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 201 Answers
  • Posted on Aug 27, 2012
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
201
Questions
0
Helped
75996
Points
491
Sounds like a power supply issue. I would test the power supply on this PC.
5 Related Answers
Anonymous
  • 91 Answers
  • Posted on Oct 08, 2007
SOURCE: Sony Vaio pcv-rs 312v
check whether your SMPS fan is running the back side of the cabinetand also the cpu fan if you can open the system case. if the both fan is running fine then rmove the CMOS battery and start the computer after 2 or 3 sec the cpu fan will stop that means BIOS is cleared reinsert the battery and boot the system go to BIOS and go to load default setting and enter(press DEL or f2 to enter BIOS) after that press f8 and go to safe mode (not work with win98)it will take some time,after getting in to the OS scan your computer for virus with best and latest updated ANTI VIRUS. let me know whether it is working ot not. if not working kindly let me know what the exact problem is write all the process you follow to start your PC reply me soon
Anonymous
  • 18 Answers
  • Posted on Nov 19, 2008
SOURCE: Sony Vaio PCV-W500GN1 shuts down moments after startup
Hi Patrick,
How did you get on with those tests ? Any joy ?
David
Anonymous
  • 32 Answers
  • Posted on Feb 11, 2009
SOURCE: Keyboard shortcut buttons not working
You must have received a Cd with your Sony Vaio model, u need to install th e software again.
thegoshem
thegoshem
  • 61 Answers
  • Posted on May 06, 2009
SOURCE: Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
Anonymous
  • 89 Answers
  • Posted on May 27, 2009
SOURCE: Sony VAIO RB30C (VGCRB30) PC Desktop Won't Turn On After reinstalling ram
Unplug the tower
Remove the ram and turn the tower on wait till it give you fast beeps. (telling you no RAM)
once that happens shut the system down by unplugging it again
Re-install your RAM and try to boot again
2helpful
My sony tv wont turn on
There is a powerbutton on my sony TV - no amount of pressing the remote will activate the telly unless I forstpop the power button on the top. Once it has been initiated teh remotes work fine.
ALSO check the remote is working by activating a digital camera - can even be a smartphone - point the remote at the lens and you should see a flashing light on the camera screen, if not, check the batteries etc (try another remote for something you know is working to compare the result)
If all that fails, it may well be the TV that's broken.
My Sony Vaio PCV-RX860 won't boot and makes a clicking sound.
It's usual that new desktop PC's have fans sounds and keyboard LED's flashing during booting..There's nothing wrong on that, as long as you can get in to your PC OS.
Computer wont turn on after lightening strike and i cant find the reset button on the inside of my sony vaio pcv-rx753. i have reset it twice in the past but now i must be blind. any ideas?
Those internal things are CMOS reset. that won't help you. but try this. Unplug the computer for a while, while cylcing the power button, then plug it back in. The power supply has an internal circut breaker and this will hold open as long as the power is still applied. once drained it will close and if it is still good you should be able to start it.
My Sony Vaio RX624's power buttone flashes orange
Is your pc not giving display? What are the number of beeps?
1helpful
Hard drive unit has a green flashing light but won't turn on
Try reseatting / swapping the memory.
How long ago did you purchase this desktop?
3helpful
Unplug the tower
2answers
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
1helpful
Computer wont start
unplug it completly and then replug it the chk if not chk for any error mesg lights etc and then let me know or mail me at [email protected]
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
