1999 Mitsubishi Mirage Logo
Posted on Dec 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change my headlight bulb
One light on my Mitsubishi libero 1994 does not work and needs replacing. how do I get into change the bulb?
  • Anonymous Mar 03, 2009
    How do i get the rubber boot off, it seems like it is glued on there?
ash seder
Level 2:
Scholar:
  • Expert 166 Answers
  • Posted on Dec 21, 2008
ash seder
Expert
Level 2:
Scholar:
Answers
166
Questions
0
Helped
73443
Points
368
Go to your parts suppler and ask for a H4 globe pop your bonnet and remove the plug on the back of your head light then remove the rubber boot paying attention to which way it cam off then you will find a spring clip unclip it but be careful not to damage its anchor point. remove old globe an throw away take new globe out of box DO NOT TOTCH THE GLASS OF THE GLOB AS IT WILL CAUSE THE GLOBE TO BLOW STAAIGHT AWAY AFTER FITTING IT handle the globe by the metle bass and fit it, refit spring clip and rubber boot fit the plugf and check the operation of the light
bingo you are done have a nice day
2answers
Headlights wont work and dash and parking lights come when ignition switch is turned on. sometimes jiggling wires works. what is the problem?
Check out related help links with solutions to troubleshoot these problem.
Click the link below directly:---
Heater fan and headlights will not turn off with ignition off? http://technoanswers.blogspot.com/2012/01/heater-fan-and-headlights-will-not-turn.html
High beams stopped working but headlights still work?
http://howtobyme.blogspot.com/2011/11/highbeams-stopped-working-but.html
Only one head light works on 2001 Dodge Caravan? http://howtobyme.blogspot.com/2011/11/only-one-head-light-works-on-2001-dodge.html
Headlight Assembly Removal On Honda Accord http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html ------------- Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html-----------
All headlights not working? http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
Headlight wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
Dash Lights And Front Marker Lights Flashing On And Off http://schematicsdiagram.blogspot.com/2012/10/dash-lights-and-front-marker-lights.html
---------- 2001 Chevrolet Tracker: Headlights and Dash lights Pulsating? http://whoisbyme.blogspot.in/2012/06/2001-chevrolet-tracker-headlights-and.html
--------- No parking lights and headlights not turning OFF? http://technoanswers.blogspot.com/2012/01/no-parking-lights-and-headlights-not.html
------------- How to replace HID headlight bulbs for lexus 400h? http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
--------- Head Lights Comes ON by Itself? http://whoisbyme.blogspot.in/2012/07/head-lights-comes-on-by-itself.html
--------- Only high beams work but head lights not working on Ford F350?
http://howtobyme.blogspot.com/2011/11/only-high-beams-work-but-head-lights.html
Only high beams working on GMC Savana?---------
Working of Headlight switch?
Both headlight bulbs blow together?
Car headlight bulbs don't last long?
How to replace Headlight Bulbs on Lincoln Town Car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-headlight-bulbs-on.html
How to change headlight?
http://repairhelpcenter.blogspot.com/2011/12/how-to-change-headlight.html
Both headlights and turn signals not working? http://schematicsdiagram.blogspot.com/2011/12/both-headlights-and-turnsignals-not.html
Headlights will not turn OFF on Ford expedition and car trailer?
http://technoanswers.blogspot.com/2012/01/headlights-will-not-turn-off-on-ford.html
Headlight Assembly Removal on 2010 buick lacrosse? http://technoanswers.blogspot.in/2012/04/headlight-assembly-removal-on-2010.html
--------- Headlights flickering and car hesitates to start?
http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
Hummers headlights flashes while start?
http://technoanswers.blogspot.in/2012/02/hummers-headlights-flashes-while-start.html
Using non-AFS headlamp assembly for AFS assembly?
http://schematicsdiagram.blogspot.in/2012/02/using-non-afs-headlamp-assembly-for-afs.html
How to replace Headlight Bulb on 2001 mitsubishi magna
http://www.howtorepairguide.com/2012/10/how-to-replace-headlight-bulb-on-2001.html
These details will help.
Thanks.
How to change headlight on 2000 galant
  • 1
    Place the Mitsubishi on a flat service in park. Set the parking brake before continuing.
  • 2Open the Galant's hood and locate the headlight cover -- roughly 3-inch wide circular piece of plastic -- behind the headlight bulb intended for replacement. Turn this cover clockwise to unlock it and pull it from the headlight assembly, exposing the headlight socket below it.
    Hold the rear of the headlight socket and turn it counterclockwise to unlock it. Pull the headlight socket and bulb from the headlight assembly.
    Grab the bulb and pull it from the socket with a slight wiggling motion.
    5
    Pick up the new 9003 headlight bulb using a clean, lint-free cloth and line up its prong with the slots in the socket. Never tough the bulb with your bare hands, as the oils left by your hands can cause the bulb to burn out prematurely.
    6
    Slide the socket and new bulb into the headlight assembly and turn the socket clockwise to lock it into place.
    7
    Place the plastic cover behind the bulb and turn it counterclockwise to lock it into place.
    8
    Repeat Steps 1 through 7 for the headlight bulb on the other side of the Galant, if needed.
    9Close the Galant's hood.
    Read more: How to Put in a Headlight Bulb on a 2000 Mitsubishi Galant ' eHow.com http://www.ehow.com/how_8210819_put-bulb-2000-mitsubishi-galant.html#ixzz27iQwCdOe
    My headlights have quit working on my 1994 Chevy 1500 pickup. I replaced the headlight switch but they still don't work. The parking lights come on but not the headlights
    Try checking both a; your fuses, and b; check your bulbs. You should have two fuse boxes, one under hood and one in or under the dash. Check those for bad, blown or weak fuses. And check your headlights bulbs for them being good and their connection. If this doesn't fix your problem, you may check out your highbeam switch.
    I have a nissan pathfinder 1994 se left high beam don't work changed bulb no help relays seem to be working they click is it possible the pig tail for bulb or headlight swtich
    Check the grounding of ur headlight! rust or oxidation prevents current to light up ur BULB. Clean & check ur hedlight connector. Tell us wut happen if u done these helpfull hints!
    1helpful
    2answers
    1994 Mercedes c280 high beams not working...
    At first 1994 C280 high beams began to not connect regularly when stick pushed forward, then not at all. Drove high beams by pulling and holding stick back towards steering wheel until that stopped working, too. Shop said the turn signal switch was at fault-- had seen it many times before with W202; about $160 to replace. Haven't done it yet, but should be an easy fix?
    2answers
    Need to change headlight on 2003 mazda rx 6
    If it is the headlight itself. There may be a cover or shroud on the front of the engin bay. Remove that, may be a combination of clips and screws. If it does not cever the light area, it is even easier. There will probably be 3 screws or nuts, remover these and unplug the electrical to the light. From there you should just be able to pop the light out of place. If you are just replacing the bulbs. Where the power goes into the assembly, turn the clip, may be grey in color and pull out of the headlight assembly and replace the light bulb. But don't touch the new bulb the oils from your skin will damage the bulb.
    28helpful
    3answers
    CHANGE HEAD LIGHT
    you change the bulb from inside the engine compartment . raise the hood and feel for a plastic retaining ring in the back of the headlite. Loosen 1/4 turn and bulb socket and old bulb will pull out from the headlite assembly Unplug the old bulb and replace with new one . assemble in reverse order.
    1994 Ford F150 Head light bulb
    i will assume you mean the headlight bulb. in the engine compartment directly behind the middle fo each headlight is the plug and bulbs. turn the round piece(will be either gray or black) and the bulb pops out. install is reverse of removal.
    Top Mitsubishi Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Thomas Perkins
    Thomas Perkins
    Are you a Mitsubishi Expert? Answer questions, earn points and help others
