Question about Sunpak Auto 555 TTL Flash
We need a manual for the Sunpak 555 TTL flash where would we get one
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: I have a Sunpak PZ42X for Canon and a Canon T1i.
I have the same problem and i dont have a idea to solve it. Did you do something?
Posted on Feb 26, 2010
I need a operating manual for Sunpak Auto Thyristor G4500DX Flash gun only
I found this for a Sunpak flash which is similar to the G4500dx:
Reading from the "auto555/G4500DX" Manual, you need to:
1. Slide the Film Selector to desired ISO - (that is the same as your camera ISO used - so, make sure you turn Off the Auto ISO feature if your camera has one).
2. Slide the Mode Selector to "A" (Auto position). This will be Auto Thyristor mode on the flash.
3. Slide the Auto F/stop Selecct Know to desired lens openning - ( so use your camera in Aperture priority mode, more in Manual to prevent changes in the camera aperture value during shooting)
Shoot, and be happy with well exposed pictures by the Auto Thyristor features of the Sunpak 555 flash.
The Sunpak 555 works great with Nikon D50, D70 cameras, as you can synchrinize flash practically at all shutter speeds. Excellent for sunny days to get narrow DOF, yet get any ambient light level contribution as desired.
For other cameras, make sure (watch out for) that Aperture Priority mode does not use shutter faster than the camera max X-sync speed - so Manual camera mode could be a better choice for a novice photographer.
In the manual there is also a list of accessories for various brand cameras, How to use Power Ratio in Manual mode, some advice on using wide lenses, how to care of your 555, and Specification section.
Minimal flash duration is 1/450 at full power, so you can safely use Auto Aperture up to 1/500 sec. Flash duration decreases with lower power setting, or lower auto mode need for poser, and the shortest flash duration is 1/17000th sec.
Jan 29, 2016 | Sunpak Cameras
Is a canon rebekt2i compadable with a sunpak555
The trigger voltage is a bit on the high side. According to this list, it's "your call." If you want to be absolutely safe, use something like the Wein Safe-Sync.
Jan 29, 2013 | Sunpak Auto 555 TTL Flash
Using a Sunpak 555 with Cybersync transmitters with a canon 40D off camera and getting inconsistent firing
did you find a solution? ive experienced a similiar problem. i think i might need to buy new flashes.
Aug 13, 2012 | Sunpak Auto 555 TTL Flash
How does the Sunpak Auto 555 Thyristor Flash Unit work concrning a battery? Does it always need the ourside battery pack unit also?
When internal cells are fully charged it do not need external ones
http://www.photographyreview.com/mfr/sunpak/flashes/PRD_84012_3121crx.aspx
Aug 07, 2010 | Sunpak Auto 555 TTL Flash
How can you connect a Sunpak 555 to a Nikon D2x?
You will need a Sunpak's PC Sync cord to Nikon D2x's PC socket.
[email protected]
Dec 15, 2009 | Sunpak Auto 555 TTL Flash
Won't flash when connected to my Nikon D80???
Set the settings to TTL for both the camera and the flash
Jun 27, 2009 | Sunpak Auto 555 TTL Flash
Sunpak PZ 4000AF for Canon EOS 35mm SLR body
Canon digital uses E-TTL metering for best flash results, the older Sunpak unit isn't compatible with this, so it is not fully compatible. It may work in manual mode - but won't be as good as a more modern compatible digital flash like the Canon or Metz (eg 58AF1 Canon) versions.
May 11, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Sunpak 555 keeps flashing on it's own
Test button pins shorted to ground.
Could also be center pin shorted to ground.
[email protected]
Nov 09, 2006 | Sunpak Auto 555 TTL Flash
Sunpak Auto 555 TTL Flash Logo
32 people viewed this question
Top Sunpak Cameras Experts
Paul Green
Andrew Taylor
Andrew Taylor
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
