Sure you can, take a look on amazon Amazon com Broan 678 Ventilation Fan and Light Combination 50 CFM and 2 5..... Have a nice day
SOURCE: QT 100L replacement
You can buy the entire motor assembly for these fans. You do not need to remove the housing. All you need to do is remove the grill, take out the guts and install the new motor assembly. It will take about 10 minutes. Here is a nutone fan motor finder.
https://www.centralvacuumstores.com/nutone/fan-motor-main.php
You can also try Nutone direct. www.nutone.com
SOURCE: replace shower fan motor in a Broan model 678
I need to get the cover off of a BROAN fan and light kit. The two solutions listed did not provide me with sufficient information. Thanks!
SOURCE: Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
